2004 F250 w/ leveling kit: Can i run 35/12.50 18" rims? - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-29-2009, 09:05 PM
mstiles19's Avatar
mstiles19 mstiles19 is offline
mstiles19 is starting off with a positive reputation.
Quote:
Originally Posted by cartmanea View Post
You can drill and tap your bump stops and screw a bolt in to make them adjustable.
awesome idea! just wondering are wheel spacers a totally bad idea?
Old 05-29-2009, 09:30 PM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
Many people use them, but I wouldn't touch them with a 10 foot pole.
Old 05-29-2009, 09:35 PM
mstiles19's Avatar
yeah that is kinda what i was thinking especially with the way i use my truck.....haha
Old 05-31-2009, 05:36 AM
high ho silver's Avatar
high ho silver high ho silver is offline
high ho silver is gaining momentum as a positive member of FTE.
Unless you remove some of the metal of the bump stop before you drill and install an adjustable bolt, the head of the bolt will be the same thickness as the nut welded to the bump stop. A lot of extra work for same outcome. The adjustment will allow you to make the gap between the spring and the tire greater but not smaller once stock tires are re-installed.
Old 07-15-2009, 07:09 AM
rigs6 rigs6 is offline
rigs6 is starting off with a positive reputation.
i know i am digging up a fairly old thread but i have been searching for answers and this has just about answered my question but just to make sure. i am going to ad a 2.5 leveling kit and found 35s mounted on 18x9 wheels with 4.53" backspacing. will they work?
Old 07-15-2009, 10:43 AM
Those will stick out pretty far and might rub your fender/bumper. Since you have an '05 you should be looking for a tire with 5-5.5" backspace on a 9" wide wheel. That wheel is about perfect for an '04 and earlier truck.
Old 07-15-2009, 06:03 PM
i have a 2004 not a 2005. i must have clicked the wrong year by mistake when i was filling out the form the other day. my mistake. so those wheels would fit perfect on my 2004?
Old 07-15-2009, 06:31 PM
That should fit very well for you then. I have 18x10 wheels with 5" backspace on my '03 and with 35x12.50" tires the tread is about 1/4" outside the fender and at full lock they are 3/4" from the leaf springs. So with a 9" wheel you could actually get away with 5" backspace and they would be tucked under the fender and go within 1/4" of the leaf springs at full lock.
Old 03-15-2014, 01:18 PM
stevo-knievo's Avatar
stevo-knievo stevo-knievo is offline
stevo-knievo is starting off with a positive reputation.
Hi,
Iím new here and Iím a newbie with trucks. I just bought my child dream Truck a Ford F-350, 2004, crew cab, Lariat, leveling kit, 6.0 Diesel, 4x4. Iím from European, Germany but I live currently in Canada.
At the moment I have (Ford) Harley Davidson 20" rims with 35" tires, Pro Comp Xtreme, 35X12.50R20. But this setup rub on the leaf springs. And I donít want spent money on spacers.
If I understand everything right, then the backspacing should not bigger than 4.5 inches.
What about the KMC Wheels? They have most likely a backspacing from 4.53 inches. Would that work as well?
Thanks a lot, Stefan
Old 03-15-2014, 01:55 PM
If you wanted to save some cash, you can keep the 20" rims and go with a narrower 35" tire. That would probably fix your rubbing issue and save you a little fuel as well. If you want to keep the 35x12.5" side, then you need to look at wheels with at least 0 offset, and as much as -12mm offset. More negative and the tires will stick out past the fenders too far and you'll need flares. I ran 35x12.50 tires on my '03 with -6mm and -10mm wheels, both fit great with the latter sticking out about 3/8" past the fender. Stock is in the +6mm range, so they only need to move out 12-18mm to get enough clearance.
Many will advise you on backspace, but backspace is depended on wheel width to really tell you where the tire will be. Offset is a measurement from wheel center, so it is independent of width and a better measurement for comparison between wheels of varying width.
Old 04-09-2014, 12:44 AM
Hi cartmanea,
Thanks you so much for your help! Thanks I really appreciated that! Thanks.
To put it plainly, my option are:
  • new narrower 35" tires. (to be honest - I could found 35X12R20 or 35X10R20 tires..)
  • wheels 20x9 or 20x10 (8/170mm) with a offset from 0 until -12
  • 4x 2 inch spacer for 8/170mm
At the moment I work in all directions. I donít have much money.
So I increase trying to find used rims or used spacer.
My daily craigslist search is: At "auto parts" with the following search term: 8/170 or 8x170 or 8 170. Itís not easy to find wheels with 0 until -12 offset.
Old 04-10-2014, 10:45 PM
so after the first seven days consciously searching craigslist (ad hunt'r) for fitting wheels without any success.
I also starting looking for cheap new wheels. My question about new wheels is: Which offset should I prefer to get a 110% rubbing free driving? -12mm?
Thanks in advance,
Stefan
  #28
Old 04-11-2014, 09:09 AM
xmontex4's Avatar
xmontex4 xmontex4 is offline
xmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to all
I XD (made by KMC) Monsters that are 18x9 and -12mm backspacing, I have about .75-1" of leaf clearance with 35x12.5r18 tires (Nitto Trail grapplers). Cartmanea knows his stuff he helped me a lot once I was ready to buy rims and tires.
IMO stay away from spacers unless you get good steel ones and those cost the same as rims so I would count those out if it was me. I would only use them on a show truck since...well its for shows lol.
  #29
Old 04-11-2014, 02:28 PM
Thanks you so much for your reply.
Yeah Cartmanea helps me a lot as well!! Thanks again Cartmanea! Now I know which wheel / offset I need.
Yeah I trying to find used wheels or real cheap new ones. That is my preferred way to do it.
The plan is to find wheels and sell my 20 inch ford harley davidson ones.
  #30
Old 04-12-2014, 02:32 AM
Happy to help!
Wheels & Tire Combo That 350 Guy 1999 to 2016 Super Duty 16 03-05-2017 02:51 PM
2012 Tire Size vs. Rim width vs. Loading 35/12.50r17 Moundainner 1999 to 2016 Super Duty 15 02-17-2016 10:57 AM
Need new tire opinions PatF250 Brakes, Steering, Suspension, Tires, & Wheels 5 09-14-2015 09:17 AM
2.5 ready lift leveling.. rim advice FORDRAIDERS6.7 6.7L Power Stroke Diesel 14 05-13-2012 05:46 PM
tire size 2006 psd fx4 2006psdCREWCABfx4 1999 to 2016 Super Duty 6 07-27-2007 06:19 AM
Tags
1250, 18, 2004, 35, cooper, duty, f150, f250, ford, inch, kit, leveling, pics, rim, rims, spacers, stt, super, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
