Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-20-2009, 07:43 AM
kirkharrod's Avatar
kirkharrod kirkharrod is offline
Garage is empty, add now
kirkharrod is gaining momentum as a positive member of FTE.kirkharrod is gaining momentum as a positive member of FTE.
So I went to a Ford/Navistar fleet maintenance seminar...
I went to a Ford/Navistar fleet maintenance seminar last night at the local Ford dealer. The Navistar guy was really down on biodiesel. He stated that the quality of bio is unregulated, showed pictures of bio that he said they had pumped that was full of water, and said that the 6.0 and 6.4s could not handle the particulates in biodiesel. He claimed it would soot up the EGR valve in no time at all. He told lots of horror stories about biodiesel.
Although the presenter claimed to not have any agenda, he was pushing everyone to use only Ford/Motorcraft parts for maintenance. He said that aftermarket filters (fuel and oil) cannot make a filter that fits correctly, because the motorcraft parts are patented. He specifically claimed that the aftermarket oil filters do not seal at the anti-drainback ports on the oil filter mount, causing unfiltered oil into the engine. He also said that aftermarket fuel filters do not have the correct lid in order to bleed out the air correctly.
He did say you could put bio in a 7.3 and it PROBABLY would not cause problems. He said bio gives you less power and less mpg. (I ve not noticed that in mine). I thought it sounded suspect. Anyone here using bio in a 6.0 or 6.4?
__________________
2002 F-250 Super Cab, 289,000 miles, 89,000 on WVO; Greasecar conversion, 20 plate heat exchanger, AIH delete-water injection in its place, DIY stock fuel bowl delete, 6637 air filter w/ Pete's cover, Straight Piped, GPR LED mod, CAT ELC, 203* thermostat, Bosch auxiliary coolant pump, ext coolant filter, fumoto oil drain valve, Aeroforce Interceptor scan gauge, ISSPro trans temp, boost, EGT, elec fuel pressure gauges, Cyberdyne coolant, veg oil, ambient air temp gauges, 80W low beams/100W high beams. No major grease related problems.
  #2 (permalink)
Old 05-20-2009, 08:16 AM
Kep4's Avatar
Kep4 Kep4 is offline
Jäger
2011 Ford F-350
Kep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant future
I agree with his statement about fuel and oil filters on the 6.0. Both were made by Racor and unlicensed, aftermarket copies do allow dirt to bypass. The bio-Diesel warning seems a bit over the top.
I've not used bio-Diesel since it's not available anywhere near me.
__________________
Russ
'12 F350 Lariat CCLB 4x4 6.7, Bilstein shocks, AmpSteps, Highway Products tool box, Duraflaps, no HPFP failure worries
'12 Fuzion 305
'05 F250 Lariat CCSB 4X4 6.0 - Sold 4/26/11 w/96,500 miles
  #3 (permalink)
Old 05-20-2009, 11:35 AM
tazo's Avatar
tazo tazo is offline
tazo is gaining momentum as a positive member of FTE.
I can understand the quality issue if not purchased from a reputable source. Here in Cal it is regulated. I have yet to get a bad tank of bio. My testimony is I have over 30k in almost 2 years running on biodiesel in my 6.0 psd. During winter months I blend down to B50 when it gets into the 20's and B80 when it is in the 30's. From mid April to mid Oct I run B100. The only problems I have had is a couple of emergency fuel filter changes when first started using bio. I was getting all the old diesel build up out of the tank. I really don't understand why the manufacturers are so against biodiesel. They must have their hands tied with the oil companies.
I have 72k on the odo and have never even had the egr touched. So I don't believe the egr statement from the rep is valid.
__________________
2005 F350 6.0 lariat supercab 4x4 long bed zf6 speed and a real work horse--Burning B100 on nice days and B50 when there is a chill in the air
Mod's-BD exhaust brake-Dura flaps-Piaa back up lights-C-Betr mirrors
-Midwest short throw shifter-Splitz lift-Wilson cell antenna & Amp--Isspro ev gauges-fuel-pyro-ebp
1999 EB expedition (Wife's)
  #4 (permalink)
Old 05-20-2009, 11:44 AM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Mine's a 7.3, but I think the less mpg and power claim is questionable. Supposedly bio does produce fewer BTU's (97% of diesel?), but I don't notice a difference myself. As far as mileage, if any thing might be slightly better. Maybe it's different with newer motors?
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #5 (permalink)
Old 05-20-2009, 12:16 PM
tazo's Avatar
Quote:
On my 6.0psd I do notice a little less power. I also get a little less mpg. Around 1 mpg less. I am on the fence of getting an Airdog. Maybe a helper pump might bring the mpg back up? I also thought of getting a tuner to advance the timing. I do believe that these newer motors are very finicky about fuel quality.
__________________
  #6 (permalink)
Old 05-20-2009, 04:05 PM
F250_'s Avatar
F250_ F250_ is offline
Still learning every day!
2002 Ford F-250
F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.F250_ has a spectacular reputation.
This doesn't answer the OP's question directly, but is related... I've seen a 1.0-1.5 mpg drop in my 7.3L with B20.
__________________
Pete (F250_) -- PAA#19
'02 F250 PSD, CC, SB, XLT, 2WD: 231K miles
Basic, low cost, not really performance enhancing mods.
'03 Excursion PSD, 2WD, 165K miles - Stock.
http://guzzle.rbmicro.com/7pt3/Mods.html
  #7 (permalink)
Old 05-20-2009, 08:12 PM
juneau76's Avatar
juneau76 juneau76 is offline
2010 Ford F-150
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
I see a 1.0-1.5mpg drop, as well, in my 6.0L. I haven't really noticed any power loss, but I run B20 max since that's all I can get here. Did anyone question why they list B5 as acceptable in the owner's manual since they think it is so bad?
__________________
Brad
2010 F-150 XLT Supercrew 4x4 5.4L
2013 Explorer Limited (The wife's family truckster)
Quote:
You haven't lived life until you've done 110mph in a Yugo
  #8 (permalink)
Old 06-16-2009, 05:45 PM
Buzzard_Wing's Avatar
Buzzard_Wing Buzzard_Wing is offline
Buzzard_Wing is starting off with a positive reputation.
I am still very new to this diesel, much less bio. But there is a 'brewer' nearby and I think I can get B20 delivered to the driveway ($2.39/gal).
I think a big part of the 'problem' is the very new diesels have some kind of exhaust burner type of deal that doesn't do well with bio. I think the older ones should be fine. The o rings (and winter) are all that really concern me.
__________________
2001 SD 7.3L PSD S-Crew Long Bed
  #9 (permalink)
Old 06-16-2009, 08:44 PM
juneau76's Avatar
2010 Ford F-150
Bio has a higher affinity for water than dino which can be a concern if it sits for any length of time or isn't handle properly.
__________________
Brad
  #10 (permalink)
Old 06-16-2009, 11:37 PM
Frankenbiker's Avatar
Frankenbiker Frankenbiker is online now
Frankenbiker is a name known to allFrankenbiker is a name known to allFrankenbiker is a name known to allFrankenbiker is a name known to allFrankenbiker is a name known to allFrankenbiker is a name known to all
frankenbiker
Quote:
Two major reasons.
1) Until very recently, there was no national standard for biodiesel, as there is for refined diesel. Thus you had a great many variations in quality, even when "properly" prepared. And as we all know, the 6.0 is VERY intolerant when it comes to fuel quality.
2) Some people are STILL confused as to what "biodiesel" means. Some think it's running straight used chicken-fryer oil, complete with bits of burnt chicken. Or french fries. Some think it's ANY vegetable-sourced oil, treated or not. Some (like me) think it's only properly de-esterified VIRGIN oil that meets the new spec.
It's an uphill battle, and one that won't be won (either way) for many years to come.
A couple of minor ones: Biodiesel doesn't like cold weather. If you're north of I-40, as often as not, you'll run into gelling problems without proper fuel treatment. Even south of I-40, it can occasionally get cold enough to be a problem. Biodiesel also picks up contaminants rather readily; much like the OLD OLD (3000 ppm sulfur) diesel we had back before the 1990's. You know, the stuff that'd clean ANYTHING.
I've often wondered what the best way of guaranteeing quality is when purchasing at retail; ask for the test results? ask for the certifications? something else?
-blaine
  #11 (permalink)
Old 06-17-2009, 12:09 AM
binuya's Avatar
binuya binuya is offline
binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.
My understanding on not being able to run bio in a 6.4 has to do with the DPF. I believe, and I'm sure someone can correct me if I'm not totally accurate, that during post combustion a small amount of fuel is injected in the combustion chamber so that further burn occurs as it enters the exhaust system. Cleaner exhaust is the desired result.
The problem with biodiesel in this system is that it doesn't completely combust and much of it winds up washing down past the piston rings and into the crankase diluting the oil.
I make my own bio and am currently running B90+ in my 7.3 and I see about 8-10% reduction in mileage and power.(Correlating BTU's as compared to #2) But I figure so what? It has phenomenal lubricity, I'm using a free waste product to make it ( that 'off the grid' feeling), and my truck's plenty powerful enough as it is for my needs.
  #12 (permalink)
Old 06-17-2009, 12:50 AM
frankenbiker
DPF's have their own fuel system. No fuel is added "post combustion" inside the engine or combustion chamber.
-blaine
  #13 (permalink)
Old 06-17-2009, 01:05 AM
binuya's Avatar
Blaine,
So I guess I misunderstood what I was told. Where on the 6.4 is the fuel being injected? I was under the impression the biggest downside to using bio in the 6.4 was unburned fuel making its way into the crankase.
  #14 (permalink)
Old 06-18-2009, 12:32 AM
Fett Affen's Avatar
Fett Affen Fett Affen is offline
2004 Ford F-Super Duty
Fett Affen is starting off with a positive reputation.
I make and run 100% most of the time in my 6.0 and have been for over 7,000 miles. The only problem I have is a little hard start first thing or if it sits for 8-10 hours on a cool day. I cycle the key twice and it usually starts up fine. It would be nice to figure out why as it doesn't do it on dino diesel but the cost savings overshadows the little bit of inconvience. My truck is also noticably quieter and runs alot smoother. You just have to check each batch for soap and total conversion. My daughters boyfriend says the exhaust smells like tacos.
Dave
  #15 (permalink)
Old 06-18-2009, 12:45 AM
binuya's Avatar
Dave,
I too, run my own B100 until it dips below 40F.
I wonder if the slight start delay might have something to do with the bio viscosity?
__________________
2001 F250 7.3 CC SB 4x4 Lariat
S&B Intake, MBRP 4" Turbo Back, HPX, AIH Delete, Hutch and Harpoon,
Isspro EV2's, Bilsteins, Warn Premium Hubs, Firestone Bags with Airlift onboard, Fumoto,
Homebrew American Biodiesel (B100 whenever I can)
1995 Mercedes Benz E300D, 2004 Mercedes ML350
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
