Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 05-20-2009, 12:43 AM
oracle oracle is offline
oracle is starting off with a positive reputation.
How to clean EGR Valve?
Hi,
I got the code about the EGR valve, I'll replace it if it throws an error again but on the meanwhile I suppose that valve should be able to get a second air by cleaning it..
Any hints on how to clean it?
Thanks
  #2 (permalink)
Old 05-20-2009, 08:27 AM
wptski wptski is offline
wptski is starting off with a positive reputation.
Quote:
Originally Posted by oracle View Post
Hi,
Thanks
Pretty hard since you can't get to the needle/seat! They are sometimes open on the side where you can see the rod from the diaphram. You'd need a vacuum pump to hold the valve open and maybe spray carb cleaner hoping it trickles down to the seat, then work the open/closed repeatedly.
The fitting from the EGR tube to the valve can be a real bugger! I ended up sawing my EGR tube on my '97 Ranger after removing the wheel, wheel well, 2/3 of the fitting, sprays and heat.
__________________
Bill
09 Ford Escape Limited, 3.0L, 4WD, AdvanceTrac
  #3 (permalink)
Old 06-30-2009, 11:29 PM
Trublufords Trublufords is offline
Trublufords is starting off with a positive reputation.
Never replaced an EGR valve on an Escape.P0401 was ALWAYS a bad PDFE sensor---Ford had a TSB on it and if it came up with a p0401--no egr flow just replace the delta pressure feedback sensor. LOL Blue
Tags
1997 , 30l , clean , cleaning , delta , egr , escape , f150 , ford , how , valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
