Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
04 Escape THUMP air conditioner on
Old 06-01-2009, 07:38 PM
lylino's Avatar
lylino
lylino is offline
My Escape makes a frequent (every 10 seconds or so) thump when the air conditioner is running. It makes this thump sound and you can feel it like the car is struggling. Anyone know what this could be?
Old 06-01-2009, 10:38 PM
scott91370's Avatar
scott91370
scott91370 is offline
My guess would be the clutch kicking in. And if you have the 4cyl it could be strong enough to pull power from the engine to run it.
Old 06-01-2009, 11:04 PM
lylino's Avatar
lylino
lylino is offline
Is this something I should worry about? Should I get it checked out?
Old 06-02-2009, 10:24 PM
scott91370's Avatar
scott91370
You're probably out of warranty so I wouldn't take it to the dealer. If you have a trustworthy mechanic I would let him check it out. Normally it's ok, but keep an ear on it and if it get's worse I would check it.
Old 06-05-2009, 07:20 PM
JFUSION's Avatar
JFUSION
JFUSION is offline
try to use the a/c on a regular basis, they say at least 10 minutes every 2 weeks minimum, even in winter months. I find they get noisy when the a/c isn't used for a while. On a 4 cyl the a/c engagement will be more pronounced and you will feel it engage and disengage at times.
JFUSION's Avatar
JFUSION
JFUSION is offline
Old 06-05-2009, 07:48 PM
lylino's Avatar
lylino
lylino is offline
thanks I was worried it could be something big
Old 06-30-2009, 10:24 PM
Trublufords's Avatar
Trublufords
Trublufords is offline
NOT EGR---more than likly Bad pressure feedback sensor---common prob.---code said no egr flow, p0401 right(pull vac on egr when running and engine idle changes drasticly-working ok,if not passage way behind egr are stopped up, my money is on bad DPFE code p0401)?Also AC runs in winter time when you select defrost, I think the only time it does not run is in off or vent position. LOL Blue
FiveOJester
09-08-2016 11:50 PM
Dwayne Oxford
1999 to 2016 Super Duty
18
08-07-2016 07:11 AM
redrangers
07-22-2015 07:48 AM
signatow
05-30-2015 10:40 PM
Pete Johnson
New Member Introductions
08-17-2004 08:21 PM
Quick Reply: 04 Escape THUMP air conditioner on
