Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Is F-150 Still King?
  #1 (permalink)
Old 05-19-2009, 11:26 PM
TrekChick's Avatar
TrekChick TrekChick is offline
TrekChick is starting off with a positive reputation.
Trailer Brake problem - Code 2808 - Any ideas??
We tow our 5'er with a 2005 F-350 diesel 6-speed that has the integrated trailer brake controller. The last few times we've towed, intermittently the "Check Trailer" light comes on. Initially, Hubby found one of the trailer brakes had a loose wire, so he fixed that up and all the other brakes checked out, but the light is still coming on. It happens mostly when we're just driving, not braking. Most recently, however, when coming to an easy stop, the truck's brake pedal seems to give way & depress suddenly just immediately before the "check trailer" light comes on, and it feels like there are no brakes at all for a split second, then the brakes grab and the trailer brakes lock up.
I took the truck (w/o the trailer) to the dealer last week and had the brakes checked (nothing wrong, pads still have 7mm), parking brake checked (they replaced the lever to set the parking brake because the ratchett wasn't working), and told them about the "check trailer" light issue. They came back with the following on my paperwork: "unable to verify trailer light coming, hook up IDS-retrieved code 2808, performed pinpoint test D1-D5, found trailer hitch connector not fully locking, remove and reinstall connector, connector plastic release/lock tab bent causing concern, rec. trailer hitch connector to start - customer declined at this time". I declined to have the plug-in in the bed replaced, because Hubby said he could do it.
So, tonight, Hubby removed the plug-in from the truck bed, and said that he could tell that it hadn't been removed and looked at as stated on my paperwork, and that nothing was broken or bent on it. He checked the other trailer wiring under and around the truck bed, and said it all looked good, too. We are planning on towing again this weekend, but I'm uneasy about it until this problem is resolved, for obvious reasons.
Does anyone know what code 2808 means? Has anyone had this problem, and if so, how was it resolved? Any ideas?????
Many thanks!
__________________
SILLY BOYS... Trucks Are For GIRLS !!
  #2 (permalink)
Old 06-28-2009, 07:37 PM
TrekChick's Avatar
I think we have a fix... finally!! Took the truck & trailer to an RV Repair shop a couple weeks ago and they rewired some stuff and changed out the 7-way system for a 4-way system (or maybe 5-way - can't remember - but I think it's a 4-way). Anyway, they eliminated the butt-connectors on our aftermarket in-the-bed plug by pulling out the 4-way connector on the bumper and direct wiring the factory wiring to a new 4-way connector in the bed. We still have the newly-replaced (and never ever used) 7-way connector on the bumper that Ford just installed in their lame attempt to solve the problem. The Repair Shop also replaced the plug end on the trailer's wiring. All I did was tow the trailer back to storage, but it seemed like everything was working fine. I think I'm going to go get the trailer out of storage tonight so I can get new tires put on it before we go up to Oregon in a couple weeks. We ended up severely flat-spotting two tires when things were all fracked up last month! It'll be another good chance to test everything out, too. What a PITA this has been.......
__________________
  #3 (permalink)
Old 06-28-2009, 08:26 PM
Steina Steina is offline
CO River Rat
Steina is gaining momentum as a positive member of FTE. Steina is gaining momentum as a positive member of FTE.
Hope everything is OK now - have a good trip and let us know when you get back.
Steve
__________________
Black 2004 Explorer XLT Sport 4.6L as my "boat hauler" for Lake Havasu/Lake Mohave runs
"I used to be wishy-washy, but now I'm not sure"
"There are 2 methods for dealing with women - neither one works"
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
