1964 f100 steering column
Steering shaft for a 64 is a solid shaft and box type.
No columns other than a 61 to 64 truck will bolt in.
You can modify the existing box and shaft to accept an aftermarket tilt. Machining of the steeriring shaft stub and fabrication of a new lower mount will be needed.
I have a 88 Truck tilt in my 64 modified to fit.
In your stock column you say it is wore out? There is only a single replaceable bearing in there. Describe wore out.
Garbz
Garbz
One bearing and retainer fit into the upper flange at the top, one of each fits into upper flange at the bottom.
2) C3DZ3517A .. Bearing
2) B1AZ3518A .. Retainer.
Both these parts are available from Ford and fit Mustangs, Falcons, Fairlanes and other 1960's cars.
1965/72 columns use the same bearings and retainers, but are in different locations.
One each is in the upper flange at the top, one each is at the bottom of the column.
1961/64: There are two steering column bearings and retainers.
rrtmpmm
Welcome to (FTE) !
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx
Ruxton5
Welcome to ( FTE ) !
You will need to check your ( Cab Mounts ) if they are wore out or rusted rotted then
as soon as you rebuild that Column it will be in the same shape real Soon ! So check
and repair or replace if needed !
Wally Womack
Welcome to (FTE) !
Ruxton5
Wally Womack
WilliamKG88
09-15-2015 08:39 PM
74lowf100
03-12-2006 07:48 PM
