1964 f100 steering column - Ford Truck Enthusiasts Forums
Old 05-17-2009, 07:00 PM
rrtmpmm rrtmpmm is offline
rrtmpmm is starting off with a positive reputation.
im switching from a 3 on the tree to a automatic and my column is wore out is there a aftermarket or other one i can bolt in easily the automatic will be a floor shifter i also prefer a tilt.
Old 05-18-2009, 01:26 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Steering shaft for a 64 is a solid shaft and box type.
No columns other than a 61 to 64 truck will bolt in.
You can modify the existing box and shaft to accept an aftermarket tilt. Machining of the steeriring shaft stub and fabrication of a new lower mount will be needed.
I have a 88 Truck tilt in my 64 modified to fit.
In your stock column you say it is wore out? There is only a single replaceable bearing in there. Describe wore out.
Garbz
Old 05-18-2009, 07:06 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
1961/64: There are two steering column bearings and retainers.
One bearing and retainer fit into the upper flange at the top, one of each fits into upper flange at the bottom.
2) C3DZ3517A .. Bearing
2) B1AZ3518A .. Retainer.
Both these parts are available from Ford and fit Mustangs, Falcons, Fairlanes and other 1960's cars.
1965/72 columns use the same bearings and retainers, but are in different locations.
One each is in the upper flange at the top, one each is at the bottom of the column.
Old 05-18-2009, 09:10 PM
it has a lot of play side to side and seems loose
Old 05-19-2009, 10:44 PM
garbz2's Avatar
How big is the gap between the steering wheel and the shift hub?
Garbz
Old 05-21-2009, 12:28 AM
Ruxton5 Ruxton5 is offline
Ruxton5 is starting off with a positive reputation.
I don't mean to hijack any thread, but I have the same problem, cept' in the 65. Numberdummy, Do you have a diagram for the 65 f100 steering column with column shift. My steering is getting very sloppy and I noticed just below the bottom flange that the bearing ring is almost hanging out. It needs attention now. Any parts list online?
Old 05-21-2009, 12:42 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK Pro-Street/StateTK is offline
Pro-Street/StateTK is gaining momentum as a positive member of FTE.
rrtmpmm
Welcome to (FTE) !
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx
Ruxton5
Welcome to ( FTE ) !
You will need to check your ( Cab Mounts ) if they are wore out or rusted rotted then
as soon as you rebuild that Column it will be in the same shape real Soon ! So check
and repair or replace if needed !
Wally Womack
Steering columns the same for all 80-86 trucks? WilliamKG88 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 09-15-2015 09:39 PM
Column shift AOD hch60 1957 - 1960 F100 & Larger F-Series Trucks 4 12-27-2014 12:33 PM
Automatic Steering Column for 1964 f100? SonyResendiz 1961 - 1966 F-100 & Larger F-Series Trucks 36 09-18-2014 12:37 PM
79 P/S automatic column EricJ WTB - Parts & other 0 01-30-2014 03:09 PM
WTB- 73-79 Tilt Column Holiver31 WTB - Parts & other 1 01-26-2014 10:05 AM
Tags
1964, 61, 63, 64, aftermarket, automatic, bearing, colum, column, ebay, f100, ford, issues, length, steering, stering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
