firing order 390 V8 - Ford Truck Enthusiasts Forums
firing order 390 V8
Old 05-16-2009, 10:22 PM
ynkstr's Avatar
ynkstr ynkstr is offline
ynkstr is starting off with a positive reputation.
firing order 390 V8
Could someone please tell me the firing order for a 390 V8.
I thought someone posted that not long ago, but I can't find it.
Thank You
~Bob
Old 05-16-2009, 11:20 PM
zenmaster's Avatar
zenmaster zenmaster is offline
zenmaster is starting off with a positive reputation.
ynkstr,
1-5-4-2-6-3-7-8
Old 05-17-2009, 11:09 AM
ynkstr's Avatar
Thank You......but maybe I worded that wrong.
Sorry.
I really wanted to know which plugs are which.
Like a spark plug wiring diagram, showing where the #1 plug is, then the #2, etc.
(I feel so silly asking this. It seems so basic that everyone should know.)
~Bob
Old 05-17-2009, 01:09 PM
zenmaster's Avatar
ynkstr,
No problem, friend.
Have a look here: http://www.clubfte.com/users/ratsmoker/FAQ.html
That should answer your question.
Find a picture here:
Good luck!
John
Old 05-17-2009, 01:10 PM
daveengelson daveengelson is offline
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Copied from Chilton's 65-80 Ford pick ups manual.
http://i300.photobucket.com/albums/n...iringOrder.jpg
Old 05-17-2009, 05:46 PM
ynkstr's Avatar
Thank You VERY much !!
~Bob
Old 05-06-2011, 08:42 PM
disbegroe disbegroe is offline
disbegroe is starting off with a positive reputation.
Forget Google. FTE rocks hard!
Old 09-01-2011, 10:28 AM
MIKES 68 F100's Avatar
MIKES 68 F100 MIKES 68 F100 is offline
MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.
THANKS , I was going to search for dist rotation today , going to drill prime the oil pump tonight on my t bird 390 motor build . this site is so cool answers seem to pop up before i ask .
2000 V8 5.4 Ford F-150 Firing order. valiantski 1997 - 2003 F150 16 01-19-2016 02:53 PM
1968 ford f-600 cylinder and firing order kgh Large Truck 2 04-02-2012 12:01 AM
Firing on 4 Cylinders!! smaki09 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 13 06-09-2011 02:39 AM
Firing order for 2002 E-150 ilkefords 1968-2013 Full Size Vans 1 08-20-2009 08:28 AM
360vs390firing order boxer.fan FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 43 04-02-2009 05:33 PM
Tags
150, 1972, 2000, 390, 61, 77, code, diagram, f150, f250, firing, ford, order, plug, spark, v8, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
