1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Program Keyless Remote
Old 05-16-2009, 07:20 PM
jd9996's Avatar
jd9996
jd9996 is offline
I have a 2001 Expedition that I just bought. Previous owner lost the keyless remote. I only have one key so I wanted to get another key as well as the remote. Can I program the remote and the key myself without the dealer doing it?
Old 05-16-2009, 08:07 PM
98expeditionXLT's Avatar
98expeditionXLT
98expeditionXLT is offline
The fob you can program yourself, but the key has to be programmed by the dealer. That is how it went for us when one of our kids lost a key with a fob for a 2000 Taurus.
Old 05-17-2009, 09:36 PM
fiveohpoepoe's Avatar
fiveohpoepoe
fiveohpoepoe is offline
If you need directions on who to program the REMOTE, Ill post/email them to you.Its simple.The key,needs to be done at the dealership.
Old 05-18-2009, 07:53 AM
c_hohensee's Avatar
c_hohensee
c_hohensee is offline
There are a few locksmiths out there who have the proper equipment to program additional keys as well. So check around.
Old 05-18-2009, 08:06 AM
98expeditionXLT
One additional comment, shop around as I found there was quite a price variation among the Ford dealers in my area for making additional keys.
Old 05-18-2009, 08:11 PM
jd9996's Avatar
jd9996
jd9996 is offline
Please send me directions to program the remote. thanks
Old 05-19-2009, 11:14 PM
minitrk's Avatar
minitrk
minitrk is offline
Not to thread jack but I have the same problem, NO remotes and one PATS key, however I do have a NON pats key as well. Can I program a 2nd & 3rd PATS key off the non pats key as long as I put the pats key next to the column?
Old 05-20-2009, 01:26 AM
alloro's Avatar
alloro
alloro is offline
Received 4,196 Likes on 2,432 Posts
In 97 and 98 you can program a second PATS key by using one existing PATS key. Starting in 99 you need 2 existing PATS keys to program in a third. And no, you cannot use to same PATS key twice, the two keys have to be different. If you do not have 2 existing PATS keys, then you're stuck going to the dealer for the programming.
Old 11-15-2009, 09:29 AM
seventyseven250's Avatar
seventyseven250
seventyseven250 is offline
I'm going to bump an old thread here to see if anyone has more info on programming a PATS key without 2 existing PATS keys. Are my options really Dealerships and locksmiths only?
I was at a dealer yesterday and they wanted about $200 for a new, programmed key.
Is there anyway to program the key using one of those OBDII code readers? Presumably it's all part of the same computer.
Old 11-15-2009, 12:37 PM
alloro's Avatar
alloro
alloro is offline
Yes
and
No
Old 11-15-2009, 02:46 PM
seventyseven250
Ouch. Clear advice, but obviously not what I was wanting to hear.
Old 11-16-2009, 08:15 PM
cecilt's Avatar
cecilt
cecilt is offline
Whne I picked up my '00 Expy a month ago it only had 1 remote and key. Went to dealer and bought a new key for $15 and they programmed it for $45. I thought about getting and 2nd fob but since this is not driven daily and my wife really won't drive it I decided the 1 fob and the outside key panel was good enough.
Old 11-19-2009, 05:55 PM
KeystoneHomeOK's Avatar
KeystoneHomeOK
KeystoneHomeOK is offline
seventyseven250 I would go to a different dealer or check with a locksmith. I lost one of the keys to a 2003 Crown Vic and ended up at a locksmith and paying $40.
Old 11-20-2009, 08:30 AM
c_hohensee's Avatar
c_hohensee
Since you have spent the money for the reprogramming once, I would suggest you get another blank off of ebay (about $10). Then take the blank to a hardware store and get it cut ( they often will do it for free). Then you can program it yourself. Put this key away and this way if you ever lose a key again you still have a second key so you do not have to go back to the dealer.
Old 11-21-2009, 12:57 PM
seventyseven250
I've been calling around the local dealers and it looks like I can save fifty bucks or so by using a different dealer. I'll get one key programmed, and then buy a blank on ebay like was suggested.
I'm a ebay guy, so that works great for me.
Just got some replacement remotes from ebay, so I'll program those and see how they work.
Quick Reply: Program Keyless Remote
