Program Keyless Remote - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 05-16-2009, 08:20 PM
jd9996 jd9996 is offline
jd9996 is starting off with a positive reputation.
I have a 2001 Expedition that I just bought. Previous owner lost the keyless remote. I only have one key so I wanted to get another key as well as the remote. Can I program the remote and the key myself without the dealer doing it?
Old 05-16-2009, 09:07 PM
98expeditionXLT 98expeditionXLT is offline
98expeditionXLT is starting off with a positive reputation.
The fob you can program yourself, but the key has to be programmed by the dealer. That is how it went for us when one of our kids lost a key with a fob for a 2000 Taurus.
Old 05-17-2009, 10:36 PM
fiveohpoepoe's Avatar
fiveohpoepoe fiveohpoepoe is offline
fiveohpoepoe is starting off with a positive reputation.
If you need directions on who to program the REMOTE, Ill post/email them to you.Its simple.The key,needs to be done at the dealership.
Old 05-18-2009, 08:53 AM
c_hohensee c_hohensee is offline
c_hohensee is starting off with a positive reputation.
There are a few locksmiths out there who have the proper equipment to program additional keys as well. So check around.
Old 05-18-2009, 09:06 AM
One additional comment, shop around as I found there was quite a price variation among the Ford dealers in my area for making additional keys.
Old 05-18-2009, 09:11 PM
Please send me directions to program the remote. thanks
Old 05-20-2009, 12:14 AM
minitrk's Avatar
minitrk minitrk is offline
minitrk is starting off with a positive reputation.
Not to thread jack but I have the same problem, NO remotes and one PATS key, however I do have a NON pats key as well. Can I program a 2nd & 3rd PATS key off the non pats key as long as I put the pats key next to the column?
Old 05-20-2009, 02:26 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
In 97 and 98 you can program a second PATS key by using one existing PATS key. Starting in 99 you need 2 existing PATS keys to program in a third. And no, you cannot use to same PATS key twice, the two keys have to be different. If you do not have 2 existing PATS keys, then you're stuck going to the dealer for the programming.
Old 11-15-2009, 10:29 AM
seventyseven250's Avatar
seventyseven250 seventyseven250 is offline
seventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud of
I'm going to bump an old thread here to see if anyone has more info on programming a PATS key without 2 existing PATS keys. Are my options really Dealerships and locksmiths only?
I was at a dealer yesterday and they wanted about $200 for a new, programmed key.
Is there anyway to program the key using one of those OBDII code readers? Presumably it's all part of the same computer.
Old 11-15-2009, 01:37 PM
Yes
and
No
Old 11-15-2009, 03:46 PM
Ouch. Clear advice, but obviously not what I was wanting to hear.
Old 11-16-2009, 09:15 PM
cecilt cecilt is offline
cecilt is starting off with a positive reputation.
Whne I picked up my '00 Expy a month ago it only had 1 remote and key. Went to dealer and bought a new key for $15 and they programmed it for $45. I thought about getting and 2nd fob but since this is not driven daily and my wife really won't drive it I decided the 1 fob and the outside key panel was good enough.
Old 11-19-2009, 06:55 PM
KeystoneHomeOK's Avatar
KeystoneHomeOK KeystoneHomeOK is offline
KeystoneHomeOK is starting off with a positive reputation.
seventyseven250 I would go to a different dealer or check with a locksmith. I lost one of the keys to a 2003 Crown Vic and ended up at a locksmith and paying $40.
Old 11-20-2009, 09:30 AM
Quote:
Since you have spent the money for the reprogramming once, I would suggest you get another blank off of ebay (about $10). Then take the blank to a hardware store and get it cut ( they often will do it for free). Then you can program it yourself. Put this key away and this way if you ever lose a key again you still have a second key so you do not have to go back to the dealer.
Old 11-21-2009, 01:57 PM
I've been calling around the local dealers and it looks like I can save fifty bucks or so by using a different dealer. I'll get one key programmed, and then buy a blank on ebay like was suggested.
I'm a ebay guy, so that works great for me.
Just got some replacement remotes from ebay, so I'll program those and see how they work.
Keyless Remote Problem 300sflyer 1999 to 2016 Super Duty 12 10-27-2012 03:41 PM
2002 F250 VSM Issues/ Remote Keyless entry cbt02diesel 1999 to 2016 Super Duty 1 09-03-2011 11:19 AM
02 key-less remote question tjc transport 1999 to 2016 Super Duty 0 11-25-2010 10:50 AM
Early 94 Keyless Remote Programing Happyreefer Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 08-04-2008 12:33 PM
Keyless entry/remote start ssjrsw 1999 to 2016 Super Duty 4 01-22-2006 08:09 AM
Tags
06, 1997, 2003, 2006, 98, expedition, f150, f250, ford, key, keyless, pats, program, programming, remote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
