Help? I want 3.5mm 'AUX in' for my 2002 Trac. - Ford Truck Enthusiasts Forums
Old 05-16-2009, 04:15 PM
Sam_Fear's Avatar
Sam_Fear Sam_Fear is offline
Sam_Fear has a good reputation on FTE.Sam_Fear has a good reputation on FTE.
What I'm wondering is what OEM units I could junk yard or what aftermarket unit I should look at that will fit correctly, hook up, and have an AUX jack.
I'm tired of searching and learning about this stuff. I'd like a different head so I can plug in my ipod and other player. A 3.5mm aux jack at least. The ipod control would be OK too, but I don't really care.
I've got the OEM Pioneer AM/FM/6cd (1L2F-18C815-MB) with sub and rear controls in my 2002 Explorer Sport Trac. 3-Black/Red pugs and the 4 holes for the puller keys.
Any help appreciated.
Old 05-17-2009, 01:44 AM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
I think the factory units with the analog input were all CAN units so they probably will be a pain to retrofit. Any aftermarket with RCA in can be easily adapted to 3.5mm jack. I like the stock units so I would just pick up a PIE adapter.
Old 05-17-2009, 11:32 AM
Sam_Fear's Avatar
Well, PIE is fine, but I still need a new head unit since my is bad. I'm leaning toward OEM units since everyone around here only has aftermarket DIN units or touchscreen 2DIN. Neither of which I want.
So what vehicles can I get a compatible unit from? Found out it's a 815 series.
Thanks.
Old 05-17-2009, 12:21 PM
ReAX's Avatar
The superduties went to CAN in 2005, so pretty much any 1999-2004 Superduty and I would suspect any other ford double din up to the body changes in the 2004-05 area. With the 2003-04 radios with the indash 6 disc changer, there is typically a CD-DJ feature to add another CD changer or hook up an IPOD adapter like PIEs.
Old 05-18-2009, 06:12 AM
Sam_Fear's Avatar
Thanks ReAX. That gives me a good start.
3.5mm aux input pepito113 2009 - 2014 F150 6 09-02-2015 08:21 AM
AUX problem (2007 F-150) thite88 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 06-25-2013 04:44 PM
Definitive radio upgrade for 2003 DVD with 3.5mm aux jack freesoul Excursion - King of SUVs 0 01-13-2012 05:53 PM
Aux input cable? berry1234 2007 - 2014 Expedition & Navigator 2 01-11-2008 07:38 AM
07 Radio Aux Jack For Ipod What Size desertford 2004 - 2008 F150 4 02-28-2007 05:10 PM
Tags
18c815, 18c815mb, 1l2f18c815mb, 35mm, adding, aux, f150, ford, hook, hookup, ipod, pioneer, radio, sport, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
