360 Gas Mileage ?
360 Gas Mileage ?
Has anyone done a gas mileage check on their F250 2wd 4 speed 360? Never had a 360 powered Effie but have the chance to pick up a decent project truck to restore as a tow truck for my small travel trailer. Seems to me those that had 360's back in the day complained about poor mileage and lack of power. Anybody do an interesting engine swap in this configuration? Leaning towards 4.9EFI (like the economy and torque) or possibly 4BT (don't like the way 4BT prices have skyrocketed or the steering interference issues) if the 360 isn't up to it or is gas hog.
jeez guys, mine is so dang wore out it hardly holds 10 psi oil at an idle, and if i babied it it would get just over 13.
73 f250 4x4
360, np435
4.10's, 33x12.50's
i did a full tune up, although i have a strange way of tuning the carb. replaced pass. side exhaust manifold. I had changed all of the oil (tranny stuff was like thick goopy metallic mud) fixed a hub that didnt like to unlock. and pumped the hell out of the tires.
that was figured 1/2 town(roughly 4 lights) and 1/2 highway at 65. after calculating how much the odometer was being off, and using the same gas pump.
however if i drove it whith a heavy foot and really hammered through the gears, raced it, or played in 4wd, it would only get about 7...
73 f250 4x4
360, np435
4.10's, 33x12.50's
73 f250 4x4
360, np435
4.10's, 33x12.50's
73 f250 4x4
360, np435
4.10's, 33x12.50's
Sounds about right, FE stands for "fuel economy" right? lol
Well, my "360" gets around 20 average and as high as 24 when I kept it under 70 on the freeway. You would have to do one of those "interesting" engine swaps to get there though. Check out the many different oil pans available for the 6bt before you fret too much about steering issues.
I wouldn't do a 6BT swap, but would do a 4BT if that's the final decision, as the even with it's recent increase in popularity, the four banger is still cheaper. It's a little more difficult swap a Cummins into a 2wd, as the tie rods go smack dab through the middle of the oil pan and swapping over to a 4wd ahead of the axle steering setup is somewhat of a pain. On your 4wd you simply had to notch the crossmember for clearance, right? That is quite amazing fuel economy when you swap over to an oil burner! Has anyone done the Hercules-White bread truck engine swap into a 2wd? I heard that it can fit in with no interference issues but have no firsthand knowlege. Anybody do an 360FE EFI conversion?
Bullseye72
17
12-16-2014 11:24 AM
Bftford
01-24-2014 04:02 PM
Builtfordtough0
05-19-2013 01:14 PM
Southtowns27
07-01-2006 01:38 PM
