Moving ahead with engine.
I was in the same boat as you a few months back. I wanted to do the rebuild myself on my 223 but my limited expirence and tool cost told me no. I dropped it off at a shop this winter and told the guy to take all the time he wanted, I was in no hurry. I got it back this weekend. It was totaly redone. Everything is new except the crank. Parts were around $650 and total cost was about $1200, Included acid wash, primed and flywheel reground. I'm happy with that since I budgeted 2k for the final cost.
Does the crank pully on the front of the engine move forwards a similar amount when you push in the clutch? How do you know the flywheel is moving? 1/4" is an awful lot of movement even with the thrust surface on the main bearing having severe wear. Also that much wear with only 75K miles? Did someone run it for an extended amount of time with no oil in it while riding the clutch pedal? Sorry, but to me it doesn't likely add up to a bearing issue, look more closely for an external cause.
sammycooks
17
07-18-2013 06:11 PM
Finger__Rachet
01-01-2013 07:08 PM
FalconStng
11-13-2005 02:53 PM
BigBrownTruck
03-15-2001 12:20 AM
