Is there a "normal" interval for this message to appear? What is happening while this is displayed? Can't find anything in manual. 2008 F-250 6.4L, 4x4.
It is using diesel to burn off the filter cake. You will notice your fuel economy will drop about 2/10 mpg when it finishes. Mine runs every other time I drive the truck it seems. I hate it. I average 12.5 mpg between burn cycles. This is the worst engine Ford ever built.
Doesn't seem to be a normal interval for the cleaning to take place. Seems to happen more often when driven in stop and go city driving than on the open road. It does take a little extra fuel to burn the filter clean. The cleaning time should last around 20 miles to complete. Oh yea, it usually has poor timing when it does go into the cleaning stage. Seems to like to do it just about the time I get home and ready to pull it into garage. One thing you don't want to do if you can help it, is to turn off the engine before the cleaning cycle has completed.
__________________
2006 F-250 Reg Cab XL V-10 6-Speed Gas Beast
2008 F-550 Regency Hauler 6.4 PSD Diesel Beast
2006 Ford F-150 Crew Cab XLT 4.6 V-8
1977 F-600 Cab-Chassis V-8 4-speed 2-speed rear end
2006 Lincoln LS V-8
And, the 6.4 is not the worst engine Ford has ever come out with. It is however the first diesel that Ford has come out with to meet the current/future tough EPA demands.
So let's not blame Ford for the relatively small number of problems that have shown up. In the over-all vast number of 6.4 PSDs on the road, and given the total number of problems, it is a very small percentage of units effected.
There also is the internet which allows that small percentage of less than 100% pleased owners/want a be owners/ and owners of the compation/and gas powered trucks a venue to complain and blow little things into a much larger situation than the truth.
__________________
2006 Lincoln LS V-8
regens do vary with too many conditions to list, driving habits loaded/unloaded city vs hwy towing/no towing.
So to pin down a solid # of miles one cannot do. User results will vary. I do 400-600 miles, when towing maybe every 250 miles or so. It is not Ford's fault for sure. Blame it on the EPA and the tree huggers who think it is good for the enviroment to use more fossil fuels by trapping the soot for later burn off's.
__________________ 2008 F250 PSD Crew Cab 4x4, X-liner,
Cooper Discovery STT LT275/70R18's
Skyjacker dual steer stabilizer
Banks Ram Air & 6-Gun, Upfitter switches
Ravelco Alarm System, Frontier Extreme FT. Bumper
They should take a few of those tree huggers and have them stand next to the exhaust pipe during a regen cycle.....that is one nasty smell as it burns off the filter crap.
Next someone needs to ask the EPA, why in a time where we are trying to ease the our dependence of fuel imports, they inpose regulatons that hurts benifits and the economy of the diesel engine.
Keep in mind that our country depends on commercial trucking to deliver supplies all across our country. And 99% of these trucks are diesel powered. And, all of the new over the road tractors that are diesel powered are also required to meet the new EPA restrictions. Guess it all goes back to the old saying "If the opposite of Pro is Con...does that mean that the opposite of Progress is Congress?"
__________________
2006 Lincoln LS V-8
I have an 08 Super Duty with the 6.4. The other day, the regen cycle went on for about a day and a half. It came out of it, but I'm curious if anyone has run across this before?
Did the regen ever fully complete during any of the times you had the truck running during that period? (of course it full completed at the end of the day and a half period).
The reason I ask is if you don't keep the truck running until the regen completes its cycle, it just starts another regen cycle the next thime you start the engine. Around-town driving makes the situation even worse because it takes longer to complete the regen.
I am only speaking from experience with my own 2008 6.4L. Other folks may have different experiences.
That is what I would suspect as well. Get it out on the road and open it up and get it done.
Note that all that in town driving will also cause fuel in the oil. better check that out too.
Can you tell me more about the "fuel in the oil" problem caused by in-town driving. I do a lot of in-town driving and I keep my RPM's very low (under 1500 - it saves me a ton of fuel). Have I now screwed my engine?
to make regen work, the system goes into running very rich, some fuel then passes thru to the exhaust. If that is true, then some will leak past the rings into the oil. (as I understand it).
Yes in order to regenerate the DPF there is an additional injection of fuel on the exhaust stroke that goes into the exhaust.
This causes the exhaust to super-heat the DPF and burn the soot.
Unforunately this technology does not work well with low speed or in city driving. This low speed or in city driving only prolongs the event.
It also tends to wash the cylinders with fuel I think because there is not enough of a force from the exhaust gases to get it where it really needs to go.
So do monitor your oil. I would tell you to check your oil weekly anyway as a pm item.
I use my B trip meter to monitor my in between regens so I have an idea on when I will do one for myself. Might help you some too.
Seems to me that what I would do is get it on the highway once a week and run it hard. that may help the most.
