Sorry, I forgot to mention that I am also thinking of upgrading the turbo system to a late 99+ with a highlow turbo (yet to be determined) and putting in a high pressure HPOP.
Then you'll need to upgrade the intake plenums and Y pipe I do believe. Dieselsite has the new adreniline pump, and Terminatorengineering has the modified 17 deg pump, both of which would be an upgrade over the 99.5 pump, so you might as well leapfrog the late 99 pump and go for even more. Then you can ditch the Superchips for one of the more favored ones and see what the truck really has to offer.
I have seen/read of DIY injector rebuild horror stories, and the opposite. Mostly horror. I will get around to my hybrid injector post based on my conversation with Bob from Dieselsite while I was at TS Outlaw eventually. Not tonight. I need to gather info.
Originally Posted by mueckster
I want to hear what you have to say on this.
Ditto. I'd like to hear what Bob had to say as well.
For those with the bad experiences, what were the reasons? Part failures or incorrect assembly?
It is going to be hard to know what the real problem is because most people haven't done them before, might not realize they are at fault, or not want to take the responsibility of incorrect assembly.
