Truck won't stay running?
Old 05-15-2009, 05:58 PM
jay54f100's Avatar
jay54f100
jay54f100 is offline
I have an 85' f250 4x4 460 4sd. I have changed the carb out, changed the fuel tank selector valve, changed the front tank and fuel pump, chaged fuel lines, changed the vapor seperator, fuel pump relay, oil presure switch. I have changed all this stuff over the past two years. I'm getting to the last resort with her. I can start the truck it will run for about 2-3 mins. and then shuts down. When i try to give it some gas it sounds like its starving for gas. Its getting spark the whole time its shutting off. It will restart after this happens with same results. Is there any thing else that might be shutting off the fuel or pump or both or anything else.
Or i have a new rear tank and do a out of tank fuel pump and direct line to the carb with a bypass presure regulator. I just don't have the time to do this swap yet. I need to get the pipes out of the way first. Any help would be greatly aperciated.
Old 05-15-2009, 07:28 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,654 Likes on 1,337 Posts
Go over to the starter relay and see if you can find the darkblue wire that goes to the fusible link, and then runs into a pink/black. If you can find this wire, disconnect it from the starter relay and hook it to the battery +, and see if it will run this way. This should hot wire the pump you have selected and make it run all the time.
Old 05-15-2009, 08:38 PM
jay54f100's Avatar
jay54f100
will it turn off when i turn thr truck off?
Old 05-16-2009, 02:57 AM
WA1986F-250's Avatar
WA1986F-250
WA1986F-250 is offline
If you directly connect it to the battery, then no, it will not turn off when the truck is shut off.
jawroper
05-26-2015 04:29 PM
naylor2009
10-28-2012 10:38 AM
CrazyMiracleMan
13
10-16-2012 03:35 PM
Duksrule
07-01-2009 10:03 AM
eckart
07-12-2003 01:07 AM
Quick Reply: Truck won't stay running?
