Belt Size
Belt Size
Any one know what length of the serpentine belt should be for a 94.5 f350 DI 7.3? I am going nuts with this. I am seeing 119 7/8 for gates at rock auto and 20 1/8 from the Motorcraft web site. The one that came off the truck is part# F5tZ-8620-A that is the one that should be 20 1/8 but it measures 19.
I turned the tensioner all the way to the stop but the Gates just wont go on. Should it still be a tight fit????
I know mine was a real pain to install, make sure you trace it around each and every pulley, mine kept popping off one of them and I coudn't get it on to save my life, good flashlight and an hour later with a ton of cussing and I finally got it.... good luck
Oh as a side note, you didn't say if you had AC or not, supposedly theres 2 belt sizes, seems even if you don't have AC the idler they put in it's place is not the same size as the AC pulley, my parts guy figured that out, also there is several widths or grooves available as well.....
Slick
Slick
Did you change the belt tensioner? the aftermarket has a longer arm
the mark of the belt length indicator must be between max and min.
<!--[endif]-->
Slick
Slick
Got the 7 rib. Going to look into the idler pulleys. Maybe someone put a larger one on by mistake. Ever since I got the truck I would hear a little squeaking after I started it then it would go away. May have been set up wrong.
Belt Numbers
Ok, just crawled under the hood and in the back box for ya, 39 degrees and windy as heck up here this morning in NW Wisc!! My new one installed is a NAPA 25-081189 my spare that I saved for a mishap on the road I believe is the original from 96 and it's a Motor Craft F6TE-8620-GA
I have AC so it should be the same as yours.......
Slick!!
Slick!!
And I dont know the lenght of the longer arm, but I think is about a 1" longer but Im not sure.
<!--[endif]-->
If you can turn the pulley all the way to the stop it should go on easy. And you might want to measure the belt or at least match it to the old one. And make sure they sold you the right pulley not one that might be larger in diameter. I saw the parts book and there is a lot of room to screw this up.
