Front Differential Oil Change? - Ford Truck Enthusiasts Forums
Old 05-15-2009, 12:02 PM
BDFD BDFD is offline
BDFD is starting off with a positive reputation.
I'm going to change the oil in the front differential this weekend on my 1996 F250 4x4/351. I'm under the impression that I need to get a pump and suck the old oil out of the fill hole in the front.
If this is how it is done (with the axle still in the truck), waht is the best way to go about it cheaply? I have my counterpart's hand pump but he says he has a hard time pumping warm 10w40 with it. I do not want to buy a $50+ electric pump for something I will only do once every so often.
Anyone got any tricks or anything? Am I even going about this the right way in the first place? Remember, 4x4 novice here...
Old 05-15-2009, 01:42 PM
jas88's Avatar
jas88 jas88 is online now
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
Why are you changing it? Unless it is an LS diff, which I don't think was even available on the '96 models, you don't need to change the fluid unless it has water in it.
Old 05-15-2009, 02:23 PM
I checked it last year when I first bought it and it was low. I topped it off and I'd just like to change it all out. The seals are somewhat blown and the oil is old and dirty.
Old 05-16-2009, 10:55 AM
I just pumped the old oil out. It was half full of water. F'ing great.
Old 05-16-2009, 04:08 PM
jk89cat jk89cat is offline
jk89cat is starting off with a positive reputation.
Quote:
yep they were, i got one too ! mostly were available on floor shift 4x4 trucks ,
Old 05-16-2009, 04:58 PM
nnero's Avatar
nnero nnero is offline
nnero is gaining momentum as a positive member of FTE.
How do you know if you have a front LS? My rear one doesn't work at all. Is there a code for this?
Old 05-16-2009, 08:28 PM
phoneman91's Avatar
phoneman91 phoneman91 is offline
phoneman91 has a good reputation on FTE.phoneman91 has a good reputation on FTE.
Quote:
Look on the VIN sticker on the driver's side door frame near the striker plate. Look at the AXLE code. If there is a three character axle code and the last character is a "2"-you have a factory front limited slip.
Old 05-16-2009, 08:33 PM
phoneman91's Avatar
My Service Manual for my 92 says that the differential oil should be changed every 100k miles.
Old 05-17-2009, 07:14 AM
fmr9 fmr9 is offline
fmr9 is gaining momentum as a positive member of FTE.
I used a small cheap hand pump from Harbor Freight. Was not real fast, but worked ok. Also handy if you get too much ATF in a tranny. Used it on my son's car for that.
Good Luck Frank
Old 05-17-2009, 12:25 PM
Question - if it turns out that I have a factory frony limited slip, do I need to put in the friction additive?
Old 05-17-2009, 02:21 PM
White Max's Avatar
White Max White Max is offline
White Max has a good reputation on FTE.White Max has a good reputation on FTE.
It wouldn't be a bad idea.
-Rod
Old 05-18-2009, 06:08 PM
Right on. I wasn't sure if the guts if the front diff has the same type of equipment as the rear.
Old 05-18-2009, 06:22 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
if you found water in your oil , i would pull the 3rd member and flush the housing to get it out. Dont get me wrong, its a suck job but so is replacing the 3rd member when it blows up when you really need it
Old 05-21-2009, 12:50 PM
Ok, help me out here (4x4 rookie). What is the third member and how do I yank it?
Old 05-21-2009, 03:19 PM
In order to pull the 3rd member, you need to pull the driveshaft,
remove the driversside axle shaft. then unbolt the 3rd member from the driverside TTB(catch the oil). Now it gets tricky. push the passenger axle inward, remove the axle "c" clip and remove the axle. now the 3rd member is out of the truck. clean the 3rd member w brake cleaner and prep it to go back in. Install is reverse of removal. Good luck. that 3rd member is heavy!!
2012 Front Differential Fluid Change parcours 2009 - 2014 F150 2 11-29-2015 01:31 PM
4x4 gear oil Jermafenser Oil & Lubrication 6 12-22-2014 02:01 PM
Differential Fluid Change aidandj 1967 - 1972 F-100 & Larger F-Series Trucks 4 07-25-2013 10:37 PM
Front diff. drain on '02 4X4 Thumper47 Ranger & B-Series 2 06-11-2010 11:41 PM
Front differential oil on 97 F350 4x4 CC auto. jdman1 1994.5 - 1997 7.3L Power Stroke Diesel 2 07-20-2007 04:41 PM
Tags
1960, 4x4, 95, bronco, change, diff, differential, explorer, f150, f250, fluid, ford, front, mountaineer, oil
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
