8.8" Ring gear and bearing cap torque?
08-03-2002, 03:20 PM
on
Hey guys... What is the torque specs on the ring gear bolts and the bearing cap bolts for the 8.8" rear end?
Not listed in my chiltons manual!
Thanks.
08-03-2002, 10:08 PM
Both the cap bolts and the ring gear bolts are torqued 70-85 ftlb. Most newer Ford manuals simply give the spec. of 77 ftlb.
08-04-2002, 12:14 AM
on
Cool, thanks!
What oil is recommended in the rearend?
Do you know the diff cover bolts torque?
Thanks again.
08-04-2002, 02:33 PM
The rear cover bolts are 25 to 35 ftlb. The driveshaft u-joint flange to companion flange bolts are 70 to 95 ftlb. if you can get a torque wrench on it.
08-04-2002, 03:52 PM
Buck268
09-24-2016 11:00 PM
11F250XL
06-09-2016 11:04 AM
dober83
09-25-2015 05:42 PM
genscripter
11-16-2012 07:56 PM
Polkat
11-27-2002 10:42 PM
02 ,
88 ,
bearing ,
bolts ,
cap ,
f150 ,
ford ,
gear ,
ring ,
specs ,
torque
