TSB 08-28-1 and hesitation in rainy weather - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 05-21-2009, 04:45 PM
sawtooth's Avatar
sawtooth sawtooth is offline
sawtooth is gaining momentum as a positive member of FTE.
Me either. My appointment is not until next Tue but i'm sure looking forward to smooth power in the rain. Let us know how it worked out once you have a chance to test out the replacement cooler.
Old 05-21-2009, 08:02 PM
Hardrock_F250's Avatar
Hardrock_F250 Hardrock_F250 is offline
Hardrock_F250 is starting off with a positive reputation.
I'm telling you it is a night and day difference, the new intercooler looked like the fins were a little bit wider than the old unit. I did not have a micrometer with me so I just used a simple ruler.
later ya'll.................
Old 05-21-2009, 08:19 PM
sawtooth's Avatar
which one is the intercooler? Thought i would take a look before she's switched out.
Old 05-21-2009, 09:15 PM
jrtraderny jrtraderny is offline
jrtraderny is gaining momentum as a positive member of FTE.
When you open the hood it's the 1'st on you see , right out in front.
jr
Old 05-22-2009, 12:17 PM
sawtooth's Avatar
So i guess its that huge radiator in the front? I hope so as last time my truck was in they stuck their foot into it smashing alot of the fins. A new one would sure look nice.
Old 05-22-2009, 12:21 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
it is the first one you see. You can follow the tubes coming from it and tell it feeds into the turbos. I hope this helps with that excessive lag and hesitation for you...my 6-gun should be today!
Old 05-22-2009, 01:27 PM
jmcbrid jmcbrid is offline
jmcbrid is starting off with a positive reputation.
Just had this completed on my truck this week. Paperwork states TSB 08-25-1. They replaced CAC COOLER ASY (front radiator). Will see how it works this weekend.
They also address TSB 09-4-1 - AC ACCUMULATOR ASSY - thumping or bang noise from the A/C unit. This noise happened each time the A/C engaged.
Old 05-22-2009, 02:20 PM
sawtooth's Avatar
We look forward to your testing. Any chance of rain for you this weekend? If so let us know how it ends up.
Old 05-22-2009, 07:04 PM
PHXDiesel PHXDiesel is offline
PHXDiesel is starting off with a positive reputation.
Does anyone know what the differences are with the new CAC? I have an early Job1 but haven't had any issues with white smoke that wasn't fixed with a new flash. I haven't had any problems towing in rain either. I'm just curious what's changed and why it would make smoke.
Also, what's the issue with the A/C? Mine has always made a thumping noise when the A/C engages, I just thought it was normal. It's never bothered me, but I have had at least one other person ask what it was.
Old 05-22-2009, 07:24 PM
ruschejj's Avatar
ruschejj ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
PHX, my early job 1 (06/07) only does the rain dance when I have a lot of weight slowing me down. I mean, if the engine downshifts, runs 2500-3000 rpms, boost pressure in the mid 30's, you're climbing a hill, and you are just able to maintain 60-65mph, like, not slow down any more. This is when my engine sputters when it's raining or really hot and humid.
Let's call it the "rain dance" from now on, sounds better.
Old 05-22-2009, 08:51 PM
Hah nice.. I like the name. Well I've never ran into the issue. We don't get a ton of humidity out here in AZ.
I can remember pulling some long steep grades in the rain without problems. I seem to get the highest boost in the rain. One trip coming out of verde valley it was raining and I was only pulling maybe 2k or 2.5k. I hit 40psi of boost for several miles without fluctuation(Yes it was very steep and I was probably doing a bit over the speed limit). I've never seen it since. The only thing I can think of is the extra humidity in the air doing something strange. No rain dance though. My build date is 02/07. I pre-ordered in mid 2006. Maybe the engineers were paying special attention to the first few batches
Old 05-24-2009, 09:25 PM
Quote:
Just towed my boat this weekend 180 mi round trip. For the first time in a year or so no white smoke or hesitation. Keeping my fingers crossed that the replacement of the CAC COOLER ASY - TSB 08-25-1 - did the trick. This morning - bright sunny day (Houston always humid) no problems. On the way home around 1p CT - the rain just came down in buckets - still no issues. I'll continue to monitor.
  #28
Old 05-25-2009, 08:04 AM
sawtooth's Avatar
This is sounding very good. Looking forward to 8am tomorrow as this is when they start on my truck. I'll let you guys know how it turns out.
  #29
Old 05-25-2009, 08:42 AM
senix's Avatar
I hope that is your fix. I never had the problem I but I can understand the frustration.
  #30
Old 05-25-2009, 11:37 AM
grizzlander grizzlander is offline
grizzlander is starting off with a positive reputation.
I have a 2008 F350 built in April of 08. Will I get a letter from Ford on this TSB to get it fixed or will I have to ask my dealer about it to get it done? I only have 2500 miles on it but no problems so far.
08 F550 misses/stumbles with a puff of white smoke Michael Roark 6.4L Power Stroke Diesel 8 03-23-2017 12:49 PM
TSB? sbraatz Escape & Escape Hybrid 3 02-04-2017 07:00 AM
Windshield washer fluid Chris 56 f6 1999 to 2016 Super Duty 9 02-06-2013 06:55 PM
08 Transmission bump?? TSB?? Sheryle Explorer, Sport Trac, Mountaineer & Aviator 7 12-21-2011 04:01 PM
Traction Control Light & ABS Light JCHH 6.4L Power Stroke Diesel 3 03-24-2010 10:52 PM
Tags
08281, 60, 64, 64l, 660r, accelerate, f250, ford, hesitates, hesitation, intercooler, list, powerstroke, symptom, truck, tsb, yamaha
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
