PCM is in drivers firewall, code is on the fender side. Use a little mirror to read code. You are looking for the bold 4 letter code. Ie. TDE1, SOD5 etc. Here PCM Codes - 1994-1997 Power Stroke FAQ
Reason: typo
On a Souper Dooty maybe but not an OBS, the inner fender is in the way and has to be moved before the PCM will come out.
It takes 30 seconds with a mirror.
Actually your bass-ackwards- SD doesn't require moving the inner fender, OBS does. I didn't have any luck with the mirror trick, I spent more time trying to fanagle the stupid mirror into a good position than it took to just yank the PCM.
OK
So I went and looked today, and was not able to find it, I Think. There is a sticker with a lot of data on it, heres whats there
Made in Brazil
IDM-100
F7TF-12B599-AA
7C12-2
7FAAO
Am I in the right spot
OK
Made in Brazil
IDM-100
F7TF-12B599-AA
7C12-2
7FAAO
Mike
That is your injector drive module, PCM is IN the firewall. All that is going to be showing is a wiring harness.
