88 & 93 frame question (trailer hitch) F-150
Old 05-13-2009, 12:03 PM
89fourx4's Avatar
89fourx4
89fourx4 is offline
So is the 88 frame and the 93 frame the same as to bolting in a trailer hitch?
I know sounds crazy but I have an 88 hitch and 93 truck, need to make sure the hitch will fit the 93.
Thanks
Old 05-13-2009, 12:40 PM
nighthawk285's Avatar
nighthawk285
nighthawk285 is offline
Nothing easier to find out then to hold it up there and see if any holes line up. You might have to drill one or two, but if you have to drill anymore than that, probably need a different hitch.
Old 05-13-2009, 01:14 PM
andym's Avatar
andym
andym is offline
If the truck has never had a hitch before, then you will need to drill all holes. I had to drill six when I bought my receiver hitch.
Aside from test-fitting it, the easiest way is to look up the part numbers for a hitch for both trucks. If they are the same, you know the hitch will fit both trucks.
Old 05-13-2009, 02:21 PM
nighthawk285
Oh really? I thought that they were pre-drilled like all the other holes in the frame... My mistake, thanks andy for clearing that up.
Old 05-13-2009, 03:52 PM
hawgystyle's Avatar
hawgystyle
hawgystyle is offline
some vehicles have the holes pre-drilled, and just today I installed one today, just had to drill two holes of the Class III hitch
Old 05-13-2009, 03:56 PM
waynaferd's Avatar
waynaferd
waynaferd is offline
Do most of those bolt to the bottom of the frame rails or sides?
I got a big 10500 # hitch from a chevy van but need to modify the brackets to fit my F-150.
Old 05-13-2009, 08:20 PM
hawgystyle's Avatar
hawgystyle
they make hitches that bolt up to the side top and bottom of the frame
Old 05-14-2009, 04:07 PM
waynaferd's Avatar
waynaferd
Aighty!!
I got like 4" of frame sticking out past the spring hangar on my shortbed, so I'm trying to make the most of it!!
mwilliams0326
Fifth Wheel & Gooseneck RV Towing
11-22-2015 04:31 PM
DR Smith
16
01-29-2014 04:59 AM
SuperDuty93
04-23-2012 09:54 PM
smashclash
11-06-2010 07:52 AM
Fordfr4x4
01-17-2008 05:43 PM
Quick Reply: 88 & 93 frame question (trailer hitch) F-150
