Difference between C4 and C6? - Ford Truck Enthusiasts Forums
Old 08-14-2002, 03:51 AM
GeneStoner GeneStoner is offline
GeneStoner is starting off with a positive reputation.
What is/are the difference(s) between the C4 transmission and the C6?
Old 08-15-2002, 08:37 PM
flyboy2610's Avatar
flyboy2610 flyboy2610 is offline
flyboy2610 is gaining momentum as a positive member of FTE.
The basic difference is the C-4 has a removable bellhousing and the C-6 does not. The C-4 is fine for small block engines or light to medium duty, but if you have a big block or intend to use your tranny in a heavy duty capacity get a C-6. The torque produced by the big blocks will shred a C-4.
Welcome to the club!
Old 08-15-2002, 09:39 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
Weight and size are the big differences too.
You can lift and wiggle a C-4 into place holding it over your head with two hands on a car. You have to work a lot harder with a C-6 on a truck :>
Old 08-15-2002, 10:20 PM
Hershey Hershey is offline
Hershey is starting off with a positive reputation.
What is the difference between the two transmissions below on the 2013 Ford Explorer 4 Wheel Drive w ITDave 2011 & Newer Explorer 3 08-27-2012 11:03 PM
C6 Tranny differences azerjeff 1973 - 1979 F-100 & Larger F-Series Trucks 5 09-26-2011 12:24 PM
C-6 Differences gt40racing 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-28-2010 02:13 PM
Differences between t-18 and np435 cipsmithers 1973 - 1979 F-100 & Larger F-Series Trucks 1 11-28-2008 02:04 AM
Ford or Lincoln C6 PoolBoy Clutch, Transmission, Differential, Axle & Transfer Case 6 12-27-2004 05:17 PM
Tags
big, block, c4, c6, dif, diference, difference, differences, drive, ford, shaft, size, small, transmission, truck, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
