300 6-cyl Carb - Page 2 - Ford Truck Enthusiasts Forums
300 6-cyl Carb
Old 05-24-2009, 01:12 PM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
If I recall right, there's tabs on two sides that have to be pushed when disconnecting them. It's been 13 years or more since I've messed with a DuraSpark wiring harness...
Carb advice mmalte2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 22 10-15-2012 02:00 PM
1984 - 1986 Sticky Thread? LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 22 01-11-2011 10:49 PM
timing ?'s after EGR removal baverwolf Ford Inline Six, 200, 250, 4.9L / 300 3 07-21-2010 08:57 PM
Questions about Feedback Carb setup AbandonedBronco Ford Inline Six, 200, 250, 4.9L / 300 5 10-07-2009 07:41 PM
Vacuum/Emissions on a '79 Canadian F-250 4x4 Tonyb7 1973 - 1979 F-100 & Larger F-Series Trucks 10 04-11-2004 10:10 PM
Tags
150, 300, 6cyl, 84, capri, carb, carburetor, conversion, cyl, cylinder, diagram, distributor, ignition, location, manual, mercury, module, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
