302 ho heads
302 ho heads
So im looking to build up a 5.0 block that ive got sitting around. I do not have heads so im looking to buy some. I do have a set of C90E 351W heads that i got a while ago, but they are bare and no port work was done so id need to get them machined and but valves/springs/etc.
So my question is what type of heads should i get for a roller cam? how much lift is going to be needed and would it be better to get a set of re-built late model heads or go ahead and grab a set of alluminum ones off of ebay or summit? i was looking at these off of ebay...
289 302 347 351w 5.0 Ford Procomp Aluminum Heads 210cc:eBay Motors (item 370198100189 end time May-16-09 13:26:29 PDT)
thoughts?
also i dont plan to do much to the bottom end other then boreing .030 over and getting new bearings and what not. I do plan to upgrade the cam, but not sure how large im going to go yet.
thoughts?
going into my daily driver, no towing just straight town/highway. and i agree those heads are not good. ive done alot of reading since posting that this afternoon. im hoping for around 300hp off of stock crank, roller cam(not sure how much yet), 1.6 roller rockers, edelbrock performer intake/600cfm carb.
on
on
There's nothing EFI specific about that cam and it's not at all compatable with SD EFI, so I don't know why Summit would list it as an EFI cam. The retrofit cam is a small base circle cam intended for use in older blocks with stock Ford lifters and spider retainer assembly. If this is what you have then it's a good choice but it's not necessary if your block is an '87 or newer casting.
i sent you a pm, but i guess i should have answered this question as well.
it does have the spider retainer and i did plan to use the stock lifters. it is a stock roller block but im really not sure how to tell if it is the type that you where talking about in the previous post. im assuming that it is not and that the retro-fit cam would be a bad choice. com cams 35-349-8 is also an option.
Busted Bones
01-18-2017 10:57 PM
Dlasure2
15
09-09-2015 11:23 AM
craigibc
08-15-2010 10:14 PM
nkapphahn
08-15-2009 10:49 AM
projectbad78
13
04-09-2009 10:38 AM
