Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 05-11-2009, 12:40 PM
FORD E-150 FORD E-150 is offline
FORD E-150 is starting off with a positive reputation.
Question blow by
my 1992 ford e-150 5.0 302
im geting blow by exhust coming out the oil fill tube
i had took it ford they told thats not good thats whats couseing my pinging but that can;t be to to i took all plugs out i found two with
oil 6 cyl & 4 cyl it only has 78k on it im hoping its the valve stem seal
i hope then i will a compression test on all cylinders and let you know
whats what and allso i have a ratle of the timeing chain may be that is caouseing the pinging but not sure any help please
  #2 (permalink)
Old 05-14-2009, 06:19 PM
Corner Gas's Avatar
Corner Gas Corner Gas is offline
Corner Gas is starting off with a positive reputation.
First of, not to be rude but you are in the wrong section. To answer your questions though. 1 check your pcv valve it may be plugged and causing blow by, if not it could be rings or valve seals. As for the pinging that is usually because your timing is to far advanced. The rattling could be your wrist pin.
__________________
Colin
2000 PSD F250XLT Ext cab, SB, 4X2
1966 Mercury F500 Still working hard
1978 F100 Custom 300 I6, 4spd std am/fm8track
1952 F1 Latest project
Life is to short to drive an ugly truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
