300/460 Air Intake Snorkel
I read here a while back that a good upgrade on a 302 or 351 is to find the air intake tube that runs from behind the grill to the airbox from a 300 or 460 motor. the tube sucks more air and is routed for a more direct charge than the 302/351 tube.
so i found one off a 300. it went on my 351 with no problem. but i noticed that the end of the snorkel that sits behind the grill is angled slightly to draw air from behind the driver side headlight. would it make sense to cut the tube slightly so to make an angle whereby it draws air more directly from the grill? this would have the effect of a "ram air" setup. as you drive down the road at speed, air would be forced into the tube as opposed to drawn in the tube.
does this make sense? i wanted to run it by you guys before i made an alterations. i'm sure i'm not the first to think of this...
moonshine34
26
11-17-2023 02:37 AM
Ford's Secret Zoodad: Putting a hole in the header panel for the snorkel to breathe - without water!
Y2KW57
22
08-26-2020 10:35 AM
Gary Lewis
106
11-29-2016 08:58 PM
LARIAT 85
01-20-2012 05:28 PM
psquare7575
38
02-17-2008 04:48 PM
