Speed Density - Ford Truck Enthusiasts Forums
Speed Density
Old 05-10-2009, 10:54 PM
nolls nolls is offline
nolls is starting off with a positive reputation.
Speed Density
How come speed density limits the mods you can make to your motor (ex. supercharger, turbo)? If you are essentially putting more air into the cylinders, won't the manifold pressure increase, and therefore the fuel injected will increase?
Old 05-11-2009, 12:59 AM
BucksTrucks's Avatar
BucksTrucks BucksTrucks is offline
BucksTrucks is starting off with a positive reputation.
I read somewhere that you can run forced induction with S/D, you only run in to problems with cams with to much overlap. And you dont want a lot of overlap with forced induction anyways.
Old 05-11-2009, 02:09 AM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
Yes you can run a supercharger on SD. Im getting one soon and running it on SD. Alot of Lightning guys still run SD but with a tune from a Tweecer.
Old 05-11-2009, 05:49 AM
frederic's Avatar
frederic frederic is offline
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
The problem is not speed density EFI. The problem is Ford speed density EFI isn't very hacked and difficult to work with because most of the Ford EEC editors (freeware and commercial) really do not support these EEC's very well, if at all.
Of course if you're familiar with the Intel 8051 processor and have countless hours to reverse engineer a particular ford EEC down to the source code level, you can make that EEC do anything you want - even control Christmas lights.
See, things like Tweecer and similar products focus on Lightenings and Mustangs, because those are the vehicles typically used as the foundation for high performance "street toys" that will have forced induction.
Old 05-11-2009, 09:17 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
As stated the Ford SD system is compatable with forced induction because these kits include an FMU to boost fuel pressure so no extra tuning is necessary. SD is only restrictive when it comes to naturally aspirated mods like cams and heads because the computer is programmed for a stock motor and has no way to recalibrate itself to these high flow components, and in general isn't supported by aftermarket tuning systems.
Old 05-12-2009, 08:13 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
Manifold pressure can't measure air flow, so if the airflow for a given manifold pressure changes (i.e. big heads or cam upgrades), the fuel calibration will be incorrect.
Speed density Sixtone 1987 - 1996 F150 & Larger F-Series Trucks 11 03-19-2015 05:26 PM
chip for speed density possible? 390Highboy Computer Chips & Tuners 7 07-17-2007 09:06 PM
speed density and 1.72 rockers cowboy4x4 1987 - 1996 F150 & Larger F-Series Trucks 7 04-07-2007 11:54 PM
Tweecer with Speed Density theedge900 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 10-19-2004 10:03 AM
Knock sensor for a Speed Density 460? LxMan1 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 12-24-2002 07:19 PM
Tags
density, eec4, ford, processor, speed, upgrades
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
