Freebies - advice on install?
Old 05-10-2009, 09:46 PM
Smokin''s Avatar
Smokin'
Smokin' is offline
Smokin
Hey guys,
So we went to visit Randy's parents this weekend, and on our way out of town we ran by his dad's shop.
SO his dad pulls me aside and starts asking me if I want some stuff for my truck. He had an '03 7.3 that he traded in on a 6.4...but pulled his goodies off before he traded it in.
This is the cool one:
I know there is a writeup on how to install these, somewhere. My question is, was the digital rearview an option on the early 99?, and if so, will I be lucky enough to find a wiring harness in the headliner somewhere?
He also gave me some really neat grill blankies, summer and winter, and a fold-up tailgate step ladder.
Old 05-10-2009, 10:18 PM
bdrummonds's Avatar
bdrummonds
bdrummonds is offline
No rear view back up system for the early 99s, and the only way you could get a compass was witht he overhead console on the Lariats. you will probably find a wiring harness in the headliner, but it probably wont be compatable with the mirror assembly.
Old 05-10-2009, 10:42 PM
Smokin''s Avatar
Smokin'
Smokin' is offline
Smokin
Thanks Brandon. I'd be happy to find power...if I have power I can make it work.
Ive always wanted a temperature/compass mirror. I'll feel all high tech now.
Old 05-10-2009, 10:45 PM
megawatt00's Avatar
megawatt00
megawatt00 is offline
Chris (F350-6) installed a Gentex on his truck. He may have the wiring diagram for it. You can pick up switched power on the same wire that is used for the guages.
Old 05-10-2009, 10:56 PM
Riffraff Diesel's Avatar
Riffraff Diesel
Riffraff Diesel is online now
PREMIUM SPONSOR
Lisa, maybe this will help you. I think you can find the wiring separately and just install. It is stand alone and doesn't require anything from our early '99 trucks factory wiring. IIRC the compass is internal so all you have to run is the power and the air temp sensor wiring. Hope that helps.
https://www.ford-trucks.com/forums/7...irections.html
Old 05-11-2009, 05:45 AM
Smokin''s Avatar
Smokin'
Smokin' is offline
Smokin
Cool. Thanks guys.
Old 05-11-2009, 06:00 AM
just another truck's Avatar
just another truck
just another truck is offline
As most said here, nothing in the headliner ( I was just there recently) but you can find a plug behind the kick plate on the passenger side.. Have fun with the install Lisa!!! Great time to install cab lights while you are there.. if you dont have them..
Old 05-11-2009, 07:25 AM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
Nice find, Lisa. I love freebies as well. There is a plug in the passenger side kick panel and there's at least one key-on power wire there.
Old 08-01-2009, 10:00 AM
Smokin''s Avatar
Smokin'
Smokin' is offline
Smokin
I am finally getting around to thinking about installing this mirror.
Anyone who has installed one have the wiring diagram that came from the manufacturer? I am electrically retarded and would like to see it.
OR...i would love to have the email of the guy who is selling these on ebay. I am searching ebay and having a hard time finding him. I searched Genex and all I found was a bunch of golfing crap.
Old 08-01-2009, 11:36 AM
F350-6's Avatar
F350-6
F350-6 is offline
Try it with a T Lisa. Gentex.
Old 08-01-2009, 11:58 AM
megawatt00's Avatar
megawatt00
I did some searching and found this for you It all depends on the model # and the # of pins or wires that the mirror has on it
PIN 1 PINK POWER +12 volts
PIN 2 BK CHASSIS, GND
PIN 3 LT GRN BACKUP LIGHTS
PIN 4 GY TO AUTO DIM OUTSIDE MIRROR
PIN 5 PINK TO AUTO DIM OUTSIDE MIRROR
PIN 6 DR GRN/WT TEMP PROBE
PIN 7 BK/WT TEMP PROBE
Update on the GNTX-126...
GRY = +Output to side dimming mirror
PNK = -Output to side dimming mirror
GNTX-104 p
WHT/RED = Accessory +12vdc
PNK = Constant +12vdc
BLK = Ground
VIO/BLK = +12vdc reverse inhibit input
ORG/WHT = Active low transistor output from auto headlights function
BRN = Second active low transistor output from auto headlights function
Edit:
This is all I could find for the 177 Lisa, they all claim to have colors on the wiring not all black like yours. Were going to have to have you check it for pin #'s
The connections to a Gentex mirror (with comp and temp). The connector pin numbers are found on the wire incursion side of the mating connector.
GM / wire harness color / function
PIN 1 / PINK / POWER +12 volts
PIN 2 / BK / CHASSIS, GND
PIN 3 / LT GRN / BACKUP LIGHTS
PIN 4 /GY / TO AUTO DIM OUTSIDE MIRROR
PIN 5 / PINK / TO AUTO DIM OUTSIDE MIRROR
PIN 6 / DR GRN/WT / TEMP PROBE
PIN 7 / BK/WT / TEMP PROBE
Note: Pin 3 is to be connected to the backup lights to turn off the auto dim feature in reverse.
I have been told that "If you intend not to use this feature connect the LT GRN wire to chassis ground. If this pin is floating the auto dim will not work properly." I have not connected this yet and it seems to function propoerly except of turning off the auto dimm when the vehicle is put into reverse. Hope this helps.
******IMPORTANT *******
DO NOT CONNECT THE LT GRN WIRE TO GROUND. THIS WIRE IS 12V WHEN THE VEHICLE IS IN REVERSE. YOU WILL BLOW A FUSE
ssj7kids
10-04-2012 08:22 PM
brando211
64
02-06-2011 01:12 AM
Randy Jack
18
06-30-2005 08:55 AM
BuiltTough
03-06-2004 07:45 AM
Annihilator
03-02-2004 06:07 PM
Quick Reply: Freebies - advice on install?
