engine swap. wiring harness? - Ford Truck Enthusiasts Forums
Old 05-10-2009, 09:32 PM
Tyler Burdett Tyler Burdett is offline
Tyler Burdett is starting off with a positive reputation.
I have a 1994 f150, 4.9l, m50d tranny, and ive been looking at a jasper remanufactured 302 for a 1994 mustang cobra. i know that the engine will fit my tranny but what should i do about my wiring harness? would a mustang or an f150 wiring harness work?
Old 05-10-2009, 11:00 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
You need a truck harness and either a truck computer or better yet a mustang computer, though you also need a mass air harness for the mustang processor.
Old 05-11-2009, 12:27 PM
so i should buy an f150 302 harness, mustang ecu, and a mass air harness?
Old 05-11-2009, 12:39 PM
Conanski's Avatar
If you can find a mass air truck harness you'll have something that fits the body correctly and will plug right in to the motor and whatever EEC processor you get. But if you can't get one you'll have to do some editing on your existing I6 harness. For that use any MAF harness from a Mustang or Lincoln or T-bird, remove the injector and mair meter wires from it and insert them into your existing truck harness. The reason the car harness isn't a direct fit is because the computer is housed on the passenger side instead of the drivers side so it's assembled all backwords.
Old 05-11-2009, 12:45 PM
wont i have to get rid of my I6 harness completely for my v8?
Engine Wiring Harness Hillcapper Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 19 09-19-2008 10:21 PM
94 150 302 to mustang 5.0L topend RustyBarnard Engine Swaps 17 10-13-2007 09:59 PM
need help swapping mustang efi into my 1988 f150 oreodog Electrical Systems/Wiring 15 06-05-2007 02:59 PM
Mustang and truck harness Dalamatition 1987 - 1996 F150 & Larger F-Series Trucks 4 09-01-2005 05:51 AM
1994 F150 racerdon 1987 - 1996 F150 & Larger F-Series Trucks 9 12-21-2003 01:09 PM
Tags
1990, 1996, 50, computer, coyote, electronic, engine, explorer, f150, ford, harness, motor, removing, swap, truck, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
