What do you guys think use gaskets or manifold direct to cyl. head ?? 78 460 F150 . I have had the manifolds resurfaced but still getting leaks between cyl. head and exhaust manifold. Did these trucks have a gasket from factory ??
If the head's exhaust flange and the manifold flange are truly flat, no gasket needed. But the chances of them being flat, unless you have just had them both machined, are about zero.
Theres a thin metal sheild type of gasket that you need to use for sure just to protect the plug wire boots & then you could get a set of copper gaskets to go between the shield & the manifolds.
Run in for awhile & then re-check those bolts.
Neil
