transmission problems with LED Bucket ligths
i have a 1997 f-350 powerstroke dual wheel 4x4 flat bed that i had installed led bucket lights on. since then i have had problems with the transmission up shifting and down shifting after 45 50 MPH. Went to a local auto parts store and they said i need a flasher. i installed the flasher and it helped with the blinker flashing fast but the transmission still fluctuates. IF anyone has had the same problem or any knowledge about this i would appreciate the help.
Unless you messed up the wiring, the two really can't be related. The turn/brake lights are simple power wires, no signals are really sent on them.
I would actually start my suspensions with the throttle position sensor. I think on the diesels it's built into the gas pedal. TPS can tell the transmission how much power your applying and it will decide to wait to shift a little longer.
Thats not entirely true. While I would suspect that the problem might lie elesewhere and your problems are circumstancial, there is a possibility that the LED brake lights can cause issues. The computer thinks that your brake lights are burned out based upon the low current draw of the LEDs. Since I knows it cannot sense when you are applying the brakes, it may change its shift pattern. You should install resistors in your brake light circuits. You can do a quick search on it to find out how to do it and what kind of resistors you need. I am going to be doing this myself, as the LED lights can also interfere with cruise control operation.
That's interesting. Does the PCM have a load sensitive circuit for the brake pedal switch? That seems like a lot of work for nothing if there isn't a way for it to display that a bulb is out. When the pedal goes down and the switch closes, then the wire has 12v. The 12v with almost no amperage should be able to tell the PCM the brake is pressed.
Interesting, I might agree w/ this if the trans was acting up w/the brake pedal depressed.
I didn't think the pcm would monitor the brake light circuit during regular driving.
Then again, I've been wrong before.
Subscribed, and re-checking for resolution !
Keep us posted.
1984_IH6.9_Project
07-27-2016 10:25 AM
