E4OD .vs. 4R100 .vs. 4R70W ? - Ford Truck Enthusiasts Forums
Old 08-19-2002, 11:10 PM
jberylecrider's Avatar
jberylecrider jberylecrider is offline
jberylecrider is starting off with a positive reputation.
Hey ya'll, can anyone tell me the differences between these trannys:
E4OD, 4R100, & 4R70W ?
My truck has the E4OD and keeps eating through them once every year and a half ($2800 every time). I would like to get a stronger tranny that will last longer. Are any of these a candidate?
I have heard that the 4R100 replaced the E4OD recently, true?
I cant imagine an E4OD holding up behind the powerstroke, but yet they came with them - I dont know why, this tranny cant even take my 220HP 5.8L for over a year, it starts slipping, overheating, & shuddering. I love how it performs when its fresh though!
I think the 4R70W is too small, does it come in smaller trucks and cars? I am just not sure, help!
Thanks!
Old 08-20-2002, 07:11 AM
rabidranger's Avatar
rabidranger rabidranger is offline
rabidranger is starting off with a positive reputation.
Have you ever got a chip for your tranny? I have the banks transcommand module, wow. What a difference. It really firms up the shifts and makes the tranny run a whole lot smoother. I have over 105K on my E40D and it is still runnin strong. You may wanna try a tranny cooler. My truck is a HD so it came stock with one. You may want to invest in a tranny temp guage as well to make sure you aren't burnin her up on the trails or anything. I do know the ones made after 96 (I think, not sure on the year) have better parts in them to make them stronger and last longer. And for $2800 you could probably get a JET E40D that would last FOREVER.
Old 08-20-2002, 12:56 PM
Oh ya, its always had a cooler, its a big one too!
I really want a tranny temp gauge, but cant find one.
1995 and up have the stronger E4OD, but mine has had all the upgrades and updates, which means it should be just as good right?
I wish the C6 had an OD! That even sounds like a good name for a tranny... EC6OD (electric C6 with overdrive). haha!
Thanks.
Old 08-24-2002, 03:28 PM
90Bronc 90Bronc is offline
90Bronc is starting off with a positive reputation.
Have you ever been to BaumannEngineering.com? They have recommendations for an E40D buildup and what to replace, unless you have already done that. B&M makes a trans temp gauge for around $60, I have one in my 90 Bronco with an E40D and 5.8. I just rebuilt the E40D with every upgrade I could find and just took it in to identify clunking in the transmission after only 3000 miles. You can try to fix em and upgrade em but I think that overall they are a horrible transmission. Good luck anyway, about the swap to a 4r100 or 4r70, I don't think that your computer will work but it's worth looking into. I know that my truck will not even start without the E40D plugged into the computer. And don't forget to make sure the housings are the same length or close or else, you'll need to lengthen/shorten ur driveshafts and modify you trans crossmember.
Alex
Old 08-24-2002, 07:13 PM
TOUGHLover TOUGHLover is offline
TOUGHLover is starting off with a positive reputation.
Tranny...which is stronger? codyingersoll123 Clutch, Transmission, Differential, Axle & Transfer Case 10 07-16-2015 04:18 PM
E4OD/4R100 to 5R110W Rocketattack Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 63 01-05-2011 10:45 PM
4R70W to E4OD deere81 Clutch, Transmission, Differential, Axle & Transfer Case 1 11-21-2009 09:23 AM
Differences in 4r70w vs. E4OD Jrock909 1987 - 1996 F150 & Larger F-Series Trucks 3 05-28-2007 01:51 AM
e4od or 4r70w delostruck Clutch, Transmission, Differential, Axle & Transfer Case 2 11-16-2006 02:07 PM
Tags
150, 1994, 1997, 4r100, 4r70w, computer, difference, e40d, e4od, f150, gauge, install, picture, run, swap, temp, tranny, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
