Trail america tires
Trail america tires
A friend and I pulled 2 3horse trailers from Tn. to tx. Phil blowed 2 tires tearing up both sides of his trailer. We both have trail america tires with low mileage but the tires made in 03 has anyone else had problems with this brand. My sisterilaw bought a set from Sundowner and with less than 1000 miles blowed all 4 tires. Tires are lt 235/85/16 e rated. What brand holds up best not fun setting on side of road with torn up trailer.
I was told to replace them every 3-4 years unless you use them constantly. They dry out, ALL tires do this. If they aren't in use they are not lubercated and dry rot. Trailers see this problem all the time because of all the time they spend parked, whereas car tires tend to be used far more. But even they can have the same issue... there was a big investigative report recently that showed that there is a high incidence of blowouts lately because tire companies were stockpiling product and the "new" tires you purchase for your car may have been sitting for 6-18 months, which kills them.
If I was towing horses I would be inclined to put a "ST" rated tire on the trailer. That being said, I have never seen a problem with Goodyear or Michelin tires in that size (LT235/85R16) and load range (E).
I never seem to keep a dual axle trailer for more then a year or two or use it much. If I did, I would probably rotate the tires, because the back axle gets the most weight, and balance the wheels.
If you want to stay with a ST rated tire I would look at Maxxis tires Maxxis - Trailer they aren't made in the US or China but have a good reputation.
I would also look at Firestone Transforce HT LT tires I know some that are running them on the RV trailers with good luck. If you do go with a LT tire be sure to say with a highway tread, the more aggressive the tread the harder the trailer is on the tires.
Denny
Nitrogen in tires- The short answer is NO. The long answer- 1. it is an extra expense. 2. Nitrogen is not available everywhere and probably not when you really need it. 3. Nitrogen is good if you plan to go a steady 150mph or better like NASCAR.
