Surging Carb.
Surging Carb.
HI All, I have a 82 / 84/ 86 ford F-350 with a 460 4X4 auto. The reason for the many years is the fact that it is made from more than one truck.
Anyway, the chassis and drive line is 1984.
The motor is a 460 with a 600 cmf Holley carb and the factory wireing for the 460. As I drive at higher speeds and at strange times, the truck will surge badly. Enough to give you wip lash! If I back off the gas, most times it will clear up. The problem is to know where to start looking. I have replaced the fuel pumps with on frame units as the tanks are 1982 replacements. I have also replaced the fuel relay.
Where do I start? I do not hear the pumps starving and I believe this is a fuel problem. Coould the oil pressure switch have a problem?
Thanks
Ken
Thanks
Ken
62-f100
11-19-2011 06:27 AM
Franken-Truck
21
08-12-2007 02:21 PM
ridgerider3
06-06-2007 06:10 PM
MrKen
02-13-2007 09:12 PM
