cat delete pipe?? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
cat delete pipe??
Old 05-09-2009, 11:35 PM
1997f350stroker 1997f350stroker is offline
1997f350stroker is starting off with a positive reputation.
cat delete pipe??
i have a 1997 f-350 with the 7.3 the exhaust is all atock and i wanted to get a cat delete pipe does anyone know where i could get this online? and how much?
Old 05-09-2009, 11:47 PM
sbxworship's Avatar
sbxworship sbxworship is offline
sbxworship is starting off with a positive reputation.
my dad wants one for his, too. I've had no luck finding just the cat delete pipe for the stock exhaust. they have 4" exhaust kits for a pretty good price on ebay, though.
Old 05-09-2009, 11:49 PM
glasseater glasseater is offline
glasseater is starting off with a positive reputation.
our stock exhaust is i believe 3 inches? you can do what i did and hollow out your cat with a whole saw and shoving a piece of pipe through the middle, that will make it look like you still have your cat on (great if your state does emissions inspections for diesels) but you'll really just basically have a "case" around a straight piped exhaust
Old 05-10-2009, 12:00 AM
if i hollow it out it wont pass emissions will it?
Old 05-10-2009, 12:12 AM
Quote:
i don't believe ANY states do smog tests for any diesel older than 1998... but if they do then you may still pass.. the cat on these trucks did barely anything at all
Old 05-10-2009, 02:00 AM
don77's Avatar
don77 don77 is offline
don77 is starting off with a positive reputation.
stock pipe is 3 1/2 summit has strait pipe and the the other stuff you need or napa
Old 05-10-2009, 02:30 AM
Oversize's Avatar
Oversize Oversize is offline
Oversize is gaining momentum as a positive member of FTE.
The state I live in does require emissions on these trucks and mine is a 96. When I bought it, it didnt have cat they required one here to pass emissions. Its just a visual inspection though meaning all they do is look to see if it has one, not wether it does anything or not. So before we put one on it we took a crowbar and a sledgehammer, and "adjusted" it by removing the guts so its just a cat shaped pipe and it passed emissions just fine.
Old 05-10-2009, 05:51 PM
cornbinder's Avatar
cornbinder cornbinder is offline
cornbinder is starting off with a positive reputation.
no boby awnsered the question. is there a cat delete pipe available for 7.3 powerstroke??
Old 05-10-2009, 06:05 PM
farmert farmert is offline
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
Pure Diesel Power shows a Diamond Eye stainless one for $62. They are a sponser listed on the left of the page.
Old 05-10-2009, 07:05 PM
Quote:
Quote:
someone did answer the question
Old 05-10-2009, 07:50 PM
MLCinNCTX MLCinNCTX is offline
MLCinNCTX is starting off with a positive reputation.
I ordered mine from The Powerstroke Shop. It is the factory "test" pipe. The cost was about $65.00.
Old 05-10-2009, 10:06 PM
richdawg's Avatar
richdawg richdawg is offline
richdawg has a good reputation on FTE.richdawg has a good reputation on FTE.
Dale @ TYMAR PERFORMANCE will have what you need.
TymarPerformance@msn.com
Future Home of Tymar Performance
Old 05-12-2009, 04:32 AM
Reptar360's Avatar
Reptar360 Reptar360 is offline
Reptar360 is starting off with a positive reputation.
ITP Diesel has this cat delete available in 3.5 or 4 inch. 94-97 Aluminized Cat Delete Pipe
Added Banks Headers- need cat delete pipe ckdc 1987 - 1996 F150 & Larger F-Series Trucks 10 04-09-2016 02:11 PM
DPF Delete pipe and still regenerating?????? Strokin82 1999 to 2016 Super Duty 16 09-29-2013 03:11 PM
another catalytic converter post fordguy2236 1997 - 2003 F150 2 05-15-2012 12:54 PM
96 f250 460 cat delete dosmthn 1987 - 1996 F150 & Larger F-Series Trucks 12 06-26-2010 04:23 AM
cat delete dmncoon 1999 - 2003 7.3L Power Stroke Diesel 10 11-11-2008 10:24 PM
Tags
1996, 73, 9497, 96, cat, catalytic, converter, delete, diesel, f150, ford, mustang, pipe, powerstroke, removing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
