'95 E4od into '93 F150 with E4od - Ford Truck Enthusiasts Forums
Old 05-09-2009, 06:21 PM
Jimkinger Jimkinger is offline
Jimkinger is starting off with a positive reputation.
I have a '93 F150 with a 302 and e4od that needs a transmission. I also have a '95 F150 with a junk 302 and a good e4od. Will the transmission from the '95 work in the '93? Do I need to swap anything other than the transmission itself? Will this work? Any help would be appreciated.
93 F150 Transmission Swap caleb_ford 1987 - 1996 F150 & Larger F-Series Trucks 0 05-31-2012 02:06 PM
Transmission and power problems? Danny93 1987 - 1996 F150 & Larger F-Series Trucks 3 06-10-2011 08:58 PM
solenoid pack pro70golfer14 1987 - 1996 F150 & Larger F-Series Trucks 3 10-14-2009 09:39 AM
'95 E4od into a '93 F150 w/ E4od Jimkinger 1987 - 1996 F150 & Larger F-Series Trucks 0 05-09-2009 04:10 PM
E4od overdrive troubles Jimkinger 1987 - 1996 F150 & Larger F-Series Trucks 2 04-22-2009 04:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
