There shouldn't be a nut? Once you get the hub off you should see the stub shaft splines. Does the nut look like an axle shaft? Cause yes, that part should spin.
Thanks for all your guys help but there it the snap ring then a washer than a nut then a washer. the nut is i think an 1 1/16 that goes ov er the spline
