HPOP diagram of drawing? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-08-2009, 05:51 PM
Texas Outlaw's Avatar
Texas Outlaw Texas Outlaw is offline
Not a liberal...
Texas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant future
Does anyone have a diagram or drawing of the HPOP? I have a small oil leak and I think that it is coming from the HPOP. It seems like it is coming from underneath it. I cannot really tell but I do know that its not coming from the fittings. I have a very small puddle of oil in the valley, right there at the HPOP. No oil anywhere else. It's not coming from the HPX or any of those lines either.
Any pics of what the underside of this thing looks like?
Old 05-08-2009, 05:59 PM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
File Type: pdf HighPressurePumpSupplementDiagnostics.pdf (812.1 KB, 3171 views)
Old 05-08-2009, 06:02 PM
if its the under side..it could be the HPOP to front cover gasket..i dont think there is a plug bottom side..
Old 05-08-2009, 06:05 PM
cleatus12r cleatus12r is online now
cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.
Old 05-08-2009, 06:26 PM
guzzle92's Avatar
guzzle92 guzzle92 is offline
guzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to all
Great pic Cody!
Old 05-09-2009, 01:27 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
Figure it out yet, Scott?
Old 05-09-2009, 01:33 AM
powerstroke8994's Avatar
powerstroke8994 powerstroke8994 is offline
powerstroke8994 is starting off with a positive reputation.
Put some dye in it and that will help. Most likely it is the pump to cover gasket. That pump is only held in there with 2 bolts so they leak easy.
Old 05-09-2009, 08:34 AM
Not a liberal...
Quote:
Thank you, Ron. That helps a lot.
Quote:
Originally Posted by cleatus12r View Post
Thank you, Cody. I copied your picture to a Word document, printed it and took it out to the truck with me.
Quote:
Not yet. Yesterday while I was looking, the motor was so hot that I couldn't touch anything. This morning, with it cold, I went out and looked under the HPOP with a mirror and it is amazingly clean there. All of the HPOP lines and fittings are clean and so is the IPR. I reached up under there and felt around and my fingers came back clean. Maybe the HPOP isn't where my leak is coming from?
The rear of the motor is dry, oil is only puddled in the front, and it's not a whole lot. The way that I found this was I noticed a quarter sized oil spot on the driveway yesterday morning as I was backing out of the driveway. Got to work, looked underneath and sure enough, a little bit of oil dripping from the inspection plate for the trans. At lunch time, I went out and climbed up onto a tire and checked the valley. Small puddle in the front. The rest of the valley was a little wet but not oily. I presume that wetness is from the small puddle being blown to the rear of the motor and out the drain to the ground.
Quote:
Going to go out and check the bolts now. Also going to check all of the intercooler boots. I know that's a long shot but hey, what the hell.
The truck is due for an oil change so thinking I will do that today too.
Old 05-09-2009, 08:40 AM
2 months ago my ICP oring leeked only when i wasnt looking...i would always see oil where you said but not a trace of where it came from..after a few weeks i see it leeking..put in a new oring and all is well thus far..
Old 05-09-2009, 08:50 AM
Not a liberal...
I will check that out next, Ron. Thanks for the tip. I hate leakers and this just won't do...ha ha.
Old 05-09-2009, 09:19 AM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Dip something down into the puddle in the valley and smell it. Make sure it's oil and not diesel you're looking at. Also check the HPO lines where they attach to the heads.
Old 05-09-2009, 09:59 AM
Not a liberal...
I did a sniff test yesterday and it sure smelled like Rotella. I changed my fuel bowl o-rings out a few months ago. I will check all of that out and see if it's wet.
Old 05-09-2009, 10:26 PM
beanhead6D5's Avatar
beanhead6D5 beanhead6D5 is offline
beanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to all
Check all the hpop plugs in the heads to see if there leaking.
Old 05-10-2009, 12:34 AM
TerminatorEng.'s Avatar
TerminatorEng. TerminatorEng. is offline
TerminatorEng. has a good reputation on FTE.TerminatorEng. has a good reputation on FTE.
Check the 11/16" plug at the rear of the pump. They are notorious for leaking. It's just a #6 O ring, same as the HPOP lines at the pump. The oil rails are #5's.
Also, check the 1/2" bolt pictured above as non-serviceable. They can also leak.
Good luck!
Old 05-10-2009, 07:37 AM
Not a liberal...
Checked all of those and they look clean. I cleaned everything up good yesterday and stuck a clean, white rag under the HPOP. Going to run it today and see if the rag gets fresh oil on it from the underside of the pump.
Oil in the valley Amicus 1999 - 2003 7.3L Power Stroke Diesel 10 06-04-2016 05:35 PM
Front of valley oil leak. What is there to leak? Firefighter 1406 1999 - 2003 7.3L Power Stroke Diesel 4 08-24-2014 09:02 AM
HPOP, Radiator Leaks, and Stop Leak? paddler 1994.5 - 1997 7.3L Power Stroke Diesel 8 04-11-2013 09:27 PM
HPOP Second Leak Failure wallsy Australia Chapter 12 03-02-2013 05:48 PM
Metal shavings on IPR screen? Piolet 6.0L Power Stroke Diesel 0 02-20-2013 09:57 PM
Tags
73, 73l, 96, diagram, diesel, f250, f550, ford, free, high, hpop, oil, pictures, pressure, pump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
