98 Merc Mountaineer front wheel bearings
nope, thats about it... loosen the axle nut and push the shaft inward an inch. That gets the CV joint away from the hub so you have more clearance to get the 3 bolts out from the back. I have a good qualilty 6 point box end wrench, with no offset. I put in on and smack with a 5 pound hammer to get them loose.
jpsage
10-19-2010 01:45 AM
