Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 05-07-2009, 09:27 PM
bismic's Avatar
bismic bismic is online now
bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold
6.0L - Difference between model years
This may be more than most folks are looking for, but here goes (I was not real organized in putting this together - there may be some repetition) ............ feel free to comment / question / correct!
Differences between 03/04 and later model trucks
2003 mid-year Model Year Changes:
http://turbodieselforums.com/downloa...004%20Book.pdf
Part way through the 2003 model year, the turbo oil supply line changed in design.
The injector harness, which runs from the FICM to each of the eight injectors, is now routed between the oil filter housing and the
compressor housing of the turbocharger.
The orientation of the injector connector retaining clip has been repositioned in order to improve serviceability.
From the beginning of production, the highpressure pump cover retains a sleeve which provides a sealing surface for the o-ring on the high-pressure oil discharge tube. Mid-way through 2003 MY, the sleeve in the high-pressure pump cover was removed.
• The sealing surface for the high-pressure oil discharge tube is now totally machined for the o-ring seal.
Midway through the 2003 MY, the injectors were changed to a more robust design: The revised clevis in the injector improves the lateral support of the plunger and dramatically reduces injector scuffing.
2004 Model Year Changes:
The six M8 bolts on the upper oil pan which were placed in thecenter of the upper oil pan have been eliminated. An upper oil pan, which has bolt holes present, should always be assembled with the six specified M8 bolts. Failure to do so will result in a vibration related noise caused from the upper oil pan vibrating against the bed plate.
The camshaft lobe separation angle, lobe lift, and duration have changed to improve combustion characteristics (Emissions).
The combustion chamber on the piston has been modified (updated bowl design).
Due to the design change of the piston, the glow plug has been made shorter by 1.2 mm. If the longer glow plugs are installed into an engine with updated pistons, glow plug to piston contact will result, ending in potential catostrophic engine failure.
The water pump impeller diameter has increased in size to 100 mm from 90 mm. Note: Both water pumps have the same bolt pattern, but a different sealing area. As a result, the smaller water pump has the physical ability to be installed into an updated front cover. If this is done, a coolant leak and over heating of the engine may result.
New FICM brackets have larger vibration insulators at each valve cover mounting point.
Beginning December 1, 2003 (engine build date), the GPCM (Glow Plug Control Module) bracket has been redesigned to accept the repositioning of the ICP Sensor. The repositioning of the GPCM improves long term reliability of the engine wiring harness. The engine sensor wiring harness and both glow plug harnesses have been changed. In order to increase the serviceability of the glow plugs, the glow plug buss bar has been replaced with a new glow plug harness. This will provide flexibility in the harness, to ease removal of glow plugs.
• In addition, the rocker-arm carrier has been modified to improve accessibility to the glow plug harness. An earlier GPCM bracket will not work on an updated 2004 MY engine.
The crankcase breather was externally mounted on the valve cover because of the redesign of the high-pressure oil rail.
In order to accommodate the change from an internal crankcase breather to an externally mounted crankcase breather, the compressor inlet duct has been modified.
The intake manifold was modified for the updated 2004 MY. The cross over section at the rear of the manifold has been eliminated.
The intake manifold was equipped with an EGRTP (Exhaust Gas Recirculation Throttle Plate) and a EGTP solenoid added.
Three fins have been added to the turbine wheel of the turbocharger. These additional fins were added to the turbine wheel in order to improve the turbocharger’s sound characteristics.
The EGR cooler has been lengthened for the 2004 MY engine to make the exhaust gases to be cooler before entering into the intake manifold.
Because the new EGR cooler is longer than the original, the exhaust up-pipe is shorter in length at the EGR cooler connection than the original up-pipe.
The turbo mounting joints have been modified. The mounting bolts no longer need spacers on the new turbo. A new turbo mounting bracket has been implemented with the mounting bolt spacers incorporated into the bracket. These spacers are utilized to achieve the necessary clamp load on the turbocharger mounting bolts.
The high-pressure oil rail has been redesigned (wavy design) to increase oil capacity and to reduce noise through the high-pressure oil system. The new design wavy high-pressure rail has increased the volume from 15 cubic inches to 30 cubic inches. This reduces pressure fall-off during injection and improved emissions and fuel economy.
• The stand pipes’ serviceability has been improved.
The high-pressure stand pipe is a two piece pipe that is sealed to the high-pressure rail and high-pressure branch by o-rings. The stand pipe has a check valve inside to limit hydraulic disturbance (feed back from injector operation). Do not disassemble the highpressure stand pipe. This will cause damage to the internal components of the pipe. If at any point, a stand pipe is disassembled, discard and replace it.
There are two new high-pressure oil rail plugs introduced with the redesign of the rail.
The ICP sensor has a new gasket.
The ICP sensor is no longer located in the high-pressure pump cover. A brass plug will replace the ICP sensor.
• It has been relocated to the front on the right high-pressure oil rail.
• The valve cover and GPCM bracket sets over the ICP Sensor.
The IPR has a new removable heat shield wrapped around it to help block excessive heat from the exhaust.
For 2004, DLC (Diamond Like Carbon) Coated Plunger on the injectors:
• The injector plunger has had a DLC coating applied to it.
• The coating will further increase the robustness of the injector against poor fuel quality/water intrusion and will reduce the risk of internal scuffing.
• Note: This injector has different operating characteristics and can not be interchanged with non DLC injectors. Installing the incorrect injector could cause erratic or rough engine operation.
More 2004 Model Year Changes
2005 Update Page 01 Running Updates
A trap was added in the fuel supply line to prevent fuel from draining out of the secondary fuel filter housing. This fuel line cannot be retrofitted to earlier MY's.
The VGT control valve has been updtaed to include a 200 micron screen. This valve can be used on 2003 and 2004 MY's.
The size of the floating bearings in the rotating group of the turbocharger have been increased in length by 1mm.
The rear crankshaft oil seal has been updated.
2005 Model Year Changes
2005 Update Page 02 Turbo-Hardware-Horsepower and Torque
http://fordpowerstrokeforums.com/dow...s%20Update.pdf
What's New in 2005:
http://www.oilburners.net/brian/6_0psd/whatsnew2005.pdf
The HPOP changed to a V4 style piston pump
The HPOP pump cover was redesigned to a cast aluminum cover
The IPR is now mounted on top of the HPOP and not on the cover. This IPR valve is NOT interchangeable w/ earlier MY's.
The HPOP discharge tube and branch tube have been modified to
accommodate the pump change
The VGT control valve has been updated to include a 150 micron screen.
The length of the High Pressure Oil rail ball tubes has been increased by 2mm.
The coolant inlet ports on the front cover have been re-positioned to accommodate the new power steering pump design.
The EGR shaft seal has been improved and the return spring tension increased.
A scoop has been added in the exhaust up pipe to help flow to the EGR valve since the throttle plate has been removed from the air inlet of the intake manifold. The EGTP (Exhaust Gas Throttle Plate) solenoid was removed.
Two divider plates have been added to the intake manifold to provide equal distribution of cooled exhaust gas to both cylinder heads.
More 2005 Model Year Changes
The high-pressure check valve has been moved from an integral part of the stand pipe to the supply port plug.
• The change began with engine build date October 28, 2004 and engine serial number 6426234 on Indianapolis built engines and 0174191 on Huntsville built engines. It can be used on earlier MY's.
The engine sensor harness has received several changes during the 2005 MY. Most of the changes have been made to reduce chafe points and provide more secure connections.
• One noticeable change is a new VGT control valve connector.
• The new connector will provide a more secure connection to the VGT control valve.
• NOTE: The VGT control valve did not change."
The Exhaust Pressure (EP) sensor has been relocated to the FICM bracket.
• This change requires a new EP tube and FICM bracket to be used.
• The engine sensor harness had to be lengthened to accommodate the new sensor location.
• NOTE: It is important to secure the nut on the EP sensor tube when removing the EP sensor.
The water pump pulley has been made more robust with the use of a thicker flange.
• The new water pump pulley design does not require the separate flange support plate as used on the previous design.
The three heat shields on the 2003, 2004, and early 2005 MY engines have now been incorporated into one large heat shield (in the rear of the engine). The new rear heat shield mounting bracket will have to be removed to gain access to the IPR valve.
The early 2005 MY Excursions were equipped with the 2004.25 MY engines.
• Beginning January 2005 all Excursions will be equipped the the 2005 MY engine.
The Mass Air Flow (MAF) Sensor has been removed from F-Series vehicles with Federal calibrations beginning in November 2004.
• The Intake Air Temperature (IAT1) Sensor will be mounted in the same location as the previous IAT1/MAF combination sensor.
The previous style turbocharger bracket has been improved to make the engine less sensitive to moan/droan concerns. This bracket was used on 2004.25 and early 2005 MY engines. The current production turbocharger bracket has been made more robust by adding material across the center of the bracket.
• The new design minimizes the moan/droan concerns.
• The current bracket went into production on January 5, 2005 beginning with engine serial number 6470111 for Indianapolis built engines and engine serial number 0189356 for Huntsville built engines.
• NOTE: The current bracket is reverse compatible with 2004.25 and early 2005 MY engines.
A new Exhaust Pressure (EP) sensor went into production on January 14, 2005. The optimized EP sensor is available as a service part for 2003.25,
2004.25, and early 2005 MY engines which use different mounting threads.
The cylinder head is now manufactured without the four outer rocker arm carrier (RAC) hold down bolt holes.
• The rocker arm carrier (RAC) still has the bolt holes in the casting with no bolts installed.
• The reason for the change is the clamp load provided by the cylinder head bolts is sufficient to for the rocker carrier.
• This change began with engine serial number 6537996 on April 5, 2005 on Indianapolis built engines.
Also:
Front brakes upgraded and changes to coil springs.
The front rotors were upgraded in 2005: 1/2"" in diameter, 1/4"" in swept radius. The major factor was the change to a more rotor abrasive friction material which kept the rotors true, and therefore less warranty for pulsation. Slide pin changes were made in an attempt to solve the disc thickness wear issue, a path that was never needed. They could have kept the first generation design and the inclusion of the rubber bushing on the end of the bottom pin in the third phase was a return to the first design characteristic. The 99-04 Akebono calipers were not a good design and since 2005, Ford returned to K-H as the caliper supplier for the platform. Also, upsized hydraulic master cylinder and larger parking brake."
Quite a few cab changes (dash, back seat, boost gauge, tow command, etc) , grill, lights, etc.
2006 Changes:
HPOP support bracket for the STC fitting. I believe it came out in mid 2006. Later (in 07 IIRC) the fitting was replaced entirely with a redesigned piece.
Commonization changes beginning in Jan 2006
Are head gaskets new on 2006 6.0s ? - Ford Truck Enthusiasts Forums
The commonized engines didn't start until Jan 06.
"Subject: 2006 6.0L Diesel Power Stroke Cylinder Head Commonization
Effective Date: Ford Production Assembly Plants - January 11, 2006
Kentucky Truck Plant (Super Duty) & Lorraine Assembly Plant (Econoline)
Description:
Changes are being made to the 6.0L diesel cylinder head, head gasket, crankcase block, rocker arm carrier and injector hold down clamps for the 2006 Super Duty and Econoline Program. The action is taking place to facilitate/communize the International manufacturing process for the upcoming 6.4L program. The 2006 6.0L used in Ford vehicles after January 11, 2006 are being referred to as ""Commonization Engines"".
Part number details are provided on a separate excel spreadsheet. "
Figure 1 - New cylinder head
1. Carrier boss bolt holes M10 x 1.5
2. Injector clamp bolt holes (relocated)
The new cylinder heads have several casting changes including a slight injector clamp bolt hole relocation (2, figure 1) and the carrier boss bolt hole size and location changes (1, figure 1). New cylinder heads also use 32 mm cup plugs replacing the old 28 mm cup plugs.
The cylinder head gasket is also new to accommodate the new 20mm cylinder head location
dowels. Pre commonization head use 18mm dowels
Note: At this time the new cylinder head assembly is not interchangeable with the previously level head.
Figure 2 – Previous Level Cylinder Head
1. Carrier boss bolt holes M8 x 1.5
2. Injector clamp bolt holes (original locations)
Note: The previous level cylinder head assembly is not interchangeable with the new head."
Figure 3 - New Block Assembly
The new crankcase (block) uses two 20mm cylinder head locating dowels per head.
The old crankcase (block) uses two 18mm cylinder head locating dowels per head.
Note: The new and old block assembly is not interchangeable. This affects replacement of all 6009 short blocks and the 6010 bare blocks.
Rocker Arm Carrier:
Figure 4 - New Rocker Arm Carrier
Casting changes to the rocker carrier provide increased clearance for new injector hold down clamps (figure 6). The new carrier also uses only 2 bolts and locating dowels to attach the carrier to the head.
The new rocker carrier is serviced in a Rocker Arm Carrier Kit which includes the rocker carrier cover, gasket and necessary dowels.
Note: The new and old rocker arm carrier kits are not interchangeable.
Figure 5 – Previous Level Rocker Arm Carrier Kit
The old rocker arm carrier uses 4 attaching bolts to hold the carrier to the old cylinder head (figure 2).
In mid 2006 (not sure of exact date) an updated support bracket was installed to strengthen the "Snap to Connect" (STC) fitting on the HPOP.
In 2007 (IIRC) the STC was replaced altogether with an upgraded part/design.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; Line-X; CPOhighway Products tool box; tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox; Re-flashed; Fuel Pressure gauge; DashDaq on deck
  #2 (permalink)
Old 05-07-2009, 09:39 PM
origcharger origcharger is online now
origcharger is gaining momentum as a positive member of FTE. origcharger is gaining momentum as a positive member of FTE.
Interesting. The terms "good work" and "above and beyond" once again seem like understatements
__________________
2004 E-450 6.0 139,000 miles
7,500 mile, 15 quart oil changes, 5W-40 Rotella.
UOAs consist of checking for metal on drain plug magnet. All stock, no mods. Dyed fuel with no additives. Never been reflashed.
Total parts replaced;
one EGR valve.
  #3 (permalink)
Old 05-07-2009, 11:19 PM
skunk250's Avatar
skunk250 skunk250 is offline
skunk250 is starting off with a positive reputation.
very comprehensive!
  #4 (permalink)
Old 05-08-2009, 10:56 AM
BPofMD's Avatar
BPofMD BPofMD is offline
Old-Timer
BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all
Should this be a "STICKY"?
__________________
BPofMD - Bud
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB CrewCab Arizona Beige
2007 Arctic Fox 30' Fifth Wheel - 1997 Lincoln Mark VIII LSC
Join the Maryland Chapter click HERE
  #5 (permalink)
Old 05-08-2009, 10:43 PM
Smiley1's Avatar
Smiley1 Smiley1 is offline
Smiley1 is starting off with a positive reputation.
I thought that they went from a nylon HPOP gear to a metal sometime in 2004 or 2005. Is this correct or am is my head up my butt?
__________________
2004 F250 CC FX4 / 46g Transfer Flow / ARP Studs / CCV / Coolant Filter
2004 Surf Side 30' pull trailer
1999 Pontiac GTP modified
1968 Pontiac Firebird (restored)
1996 Saturn SL2 commuter (37 mpg)
  #6 (permalink)
Old 05-09-2009, 12:23 AM
KRDiesel's Avatar
KRDiesel KRDiesel is offline
New Mexico CHP LDR
2003 Ford F-250
KRDiesel has a good reputation on FTE. KRDiesel has a good reputation on FTE.
Sweet, rep given!!
__________________
Steve Cox-2003.25 F-250 CC 6.0 FX4 King Ranch
4" Turbo back-Spartan Phalanx- OMG tune
Ranch Hand Cattle Guard-Hollandia sunroof
K40 2000 Radar & Laser 48 Gal fuel tank-Pioneer AVIC-D3,3 amps,12' sub, DVD, TV in headrests
JOIN NEW MEXICO CHAPTER HERE!
  #7 (permalink)
Old 05-09-2009, 03:34 PM
cartmanea cartmanea is offline
cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE.
Quote:
I doubt they ever used a nylon HPOP gear. Could you be thinking about the water pump?
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Donahoe Racing springs, Bilstein shocks,
4.30 Yukon gears, Detroit TrueTrac
- 18x10 Diamo 17 Karats, Cooper STT 35x12.50,
Off Road Tech winch bumper
- SCT Xcal2 with Spartan tunes, ISSPRO EV2 Gauges (Pyro, Fuel PSI, Boost)
  #8 (permalink)
Old 05-09-2009, 09:04 PM
mhays2's Avatar
mhays2 mhays2 is offline
mhays2 is starting off with a positive reputation.
Quote:
I agree... great work!
__________________
Mike -
2003 6.0 C.C. L.B. F350 4x4
Amsoil user with bypass, Stanadyne with every fill-up, Edge with Attitude, strait piped, reflashed
  #9 (permalink)
Old 05-10-2009, 05:18 AM
Smiley1's Avatar
Quote:
Oh no. I am sure it was the HPOP. Just cant recall if it was the internals or the drive gear. I tried a google search and came up with a post on another forum about it. I was hoping someone would be able to confirm.
__________________
  #10 (permalink)
Old 05-10-2009, 02:41 PM
diesel_dan's Avatar
diesel_dan diesel_dan is offline
FTE Addict
diesel_dan is gaining momentum as a positive member of FTE.
WoW, Mark is all can say -- you continue to provide such a valuable service to all of us. I've often though this progession of 6.0 info needed to be somewhere -- how about here?!
This should be put in the Tech Folder for sure!
Thanks! And I'd give you rep points but I am still locked out from giving you anymore (too much good stuff from your side!)...
On Edit: you mention the HPOP STC change (elimination) as Jan '07. I thought it would have been mid '06 -- in Jan '07 all engines had to be compliant with the new emissions, no? So that'd be a 6.4 if it had an engine build in Jan of '07...
__________________
'07 F350 SRW SC/LB, 6.0 PSD/Auto, 4x4 -- SuperHitch w/ custom 16" SuperTruss, Tork Lift Camper Tie-Downs, Rancho RS 9000X Shocks, Air Lift Air Springs, BFG A/Ts 285/65/18E (replacing failed 305s), GO Industries Mud Flaps.
'00 Expedition 5.4 4x4 Eddie Bauer, 3.55 LSD, HD Tow Pkg & Air Suspension -- All Bone Stock
  #11 (permalink)
Old 05-10-2009, 07:55 PM
diesel_dan's Avatar
FTE Addict
I figured out I confused model year with actual date of the change -- sorry!
__________________
  #12 (permalink)
Old 05-10-2009, 08:39 PM
mxer0022's Avatar
mxer0022 mxer0022 is offline
mxer0022 is gaining momentum as a positive member of FTE. mxer0022 is gaining momentum as a positive member of FTE.
great write up mark! i tried to give you some reps but i guess i STILL need to spread some around! i'll getcha soon!
__________________
"Ford, Because Driving A Chevy Will Give You Herpes"
2006 F-250 6.0L powerstroke cc 4X4 amarillo special edition
MBRP 4" T-409 turbo back w/cat delete
autometer Phantom II Pyro, 0-60 boost and tranny temp gauges
SCT Xcal3 w/custom tunes
  #13 (permalink)
Old 05-10-2009, 09:29 PM
6litrefan 6litrefan is offline
6litrefan is starting off with a positive reputation.
so if im reading this correctly the later 6 litres (06-07) were beefed up substantially???
  #14 (permalink)
Old 05-11-2009, 05:49 PM
I don't think they were, there is just dowel size changes and one bolt size increase. Doesn't sound substantially beefed up to me.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
