6.0L - Difference between model years - Page 2 - Ford Truck Enthusiasts Forums
Old 12-11-2009, 06:43 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Quote:
Originally Posted by delta70 View Post
I noticed that they updated the head gasket in 06. Has the improved the gasket failure for the 06 and 07? Or is it just me wishful thinking.
The head gaskets themselves have always been good. The update in 2006 was for "commonization" w/ the 6.4L. It was only to adjust for the dowel size, etc changes. the issues w/ leaking head gaskets is due to the bolts. When cylinder pressures get too high, the bolts stretch a little and never return to the original strength. Over time, leakage gets bad enough to cause puking, etc.
Old 12-23-2009, 11:16 AM
bradyracing bradyracing is offline
bradyracing is starting off with a positive reputation.
Ford says there is a difference in pumps for the 2003-2004 and the 2004.25. This has been a problem for me because I have one of the 2004.25 and all the pumps I see for sale are for the 2003-2004 or the 2005 and up pumps. The 03-04 pumps start with a 3 and the 2004.25 pump starts with a 4 with all other digits in the part number being the same. The aftermarket guys sell one pump, they don't have a separate pump for the 2004.25. Ford says because the 2004.25 oil rails increased from 15 CI to 30 CI the pump was changed. My question is what was the difference between the 04 and 04.25 pumps? The 04.25 pump has seven pistons in it, does the 03-04 pump only have six or something like that?
Old 12-23-2009, 11:35 AM
rocky1074's Avatar
rocky1074 rocky1074 is offline
rocky1074 is gaining momentum as a positive member of FTE.rocky1074 is gaining momentum as a positive member of FTE.
Another GREAT write-up Mark...Thanks
Old 12-23-2009, 10:12 PM
Really..... nothing. So the ford techs on this site have no idea what the difference is between the 04 and 04.25 HPOP pumps even though ford says there is a difference. They also seem to not know what part of the 6.0 fuel injector goes bad, the fuel end or the oil and electrical end.
Old 12-23-2009, 10:17 PM
bismic's Avatar
The late build 04s don't have the same HPOP that the 05 and up trucks do. These have the same top discharge HPOP that the 03s have but they share the "wave" high pressure oil rails with the later engines. These seemingly "hodge podge" changes can be confusing if you aren't familiar with the different "flavours" of the 6.0.
Also -
Sometime in 2004 the high-pressure oil rail was redesigned (wavy design) to increase oil capacity and to reduce noise. The new design wavy high-pressure rail has increased the volume from 15 cubic inches to 30 cubic inches. This reduces pressure fall-off during injection and improved emissions and fuel economy.
• The stand pipes’ serviceability has been improved.
Personally, I do not know the exact dates of the changes - sorry.
Also as an FYI -
From the beginning of production, the high pressure pump cover retains a sleeve which provides a sealing surface for the o-ring on the high-pressure oil discharge tube.Mid-way through 2003 MY, the sleeve in the high-pressure pump cover was removed. • The sealing surface for the high-pressure oil discharge tube is now totally machined for the o-ring seal.
Old 12-23-2009, 10:27 PM
I know this. I have the goofy hybrid of the wavy oil rails and the old swash plate pump. So what is the difference between the 2004 and 2004.25 pumps? Ford says there is a difference, so what is the difference?
Old 01-31-2010, 08:44 PM
bismic's Avatar
Just to add a little more detail:
The 06's and up had some turbo slight improvements as well as the "commonization". Larger oil drain tube and supply line and "A Revised Machined Recess Turbocharger (5c3z-6k682-ca) Designed Exclusively To Address Corrosion Related Turbocharger Performance Is Now Available In Service."
Also, sometime in 2005, the MAF was deleted, then added back in in 2006.
http://turbodieselforums.com/diesel_9.pdf
Old 01-31-2010, 08:45 PM
bismic's Avatar
Quote:
Bump for you.
Old 01-24-2011, 01:11 PM
utjer utjer is offline
utjer is gaining momentum as a positive member of FTE.
You are breaking the rules of this forum. As an attorney I am sure you know how to read.
edit - deleted the quote of someone breaking forum rules. Their post was removed.
Old 09-11-2011, 10:08 PM
cactus13's Avatar
cactus13 cactus13 is offline
cactus13 is starting off with a positive reputation.
Will '06 turbo fit my '04?
Hello, I am going to look at a used 2006 6.0 turbo to be kept as a spare. Is there a number stamped on it that will tell me if it can be installed on my '04?
Other than some change in the mounting bracket I can't find any post saying it wouldn't work as is. I assume I can upgrade the oil feed and drain lines?
Will I find the above number stamped on the housing if it is the newer recessed design?
Thank you for all the valuable info in this forum, really a lifesaver!
Old 09-12-2011, 06:09 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
04,5,6,7 turbos will all directly interchange with each other.
Old 09-13-2011, 11:05 AM
cactus13's Avatar
Thanks npcc. I picked it up yesterday and it looks pretty good. I will post some photos of it particularly of the air side intake vanes which are complete but seem a little sketchy.
  #28
Old 09-13-2011, 06:01 PM
smokersteve's Avatar
smokersteve smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
What about the 08 and 09 engines 6.0L in the e-series?
  #29
Old 09-14-2011, 01:18 AM
flamebuster flamebuster is offline
flamebuster has a good reputation on FTE.flamebuster has a good reputation on FTE.
I just installed a new front cover (where the oil and water pump are installed) on my '04 model year with a '05 year just to make sure the pump was the larger 100mm. I had to also change out the lower radiator hose due to the dfferent angle of the outlet pipe on the cover. The old one was pointed down at a angle and the newer one is staight out, making the old orginal hose too short..
  #30
Old 09-14-2011, 10:30 AM
olfordsnstone's Avatar
olfordsnstone olfordsnstone is offline
olfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to behold
My rep gun seems to be shooting blanks in your direction for now. Until I take a few shots at others on the site I'll have to keep the powder dry for your efforts here. Let me just thank you with a post of approval for now.
Thanks, good stuff! Tim
The Up(pipes), Down(pipes) and Out(exhaust) of my refresh ZachinCO 1999 - 2003 7.3L Power Stroke Diesel 16 11-23-2016 02:10 PM
COE want list WQ59B 1947 and Older Ford Trucks 5 06-15-2016 09:46 PM
Driven Diesel 6.7L Oil Pan Installed! SixPointSeven 6.7L Power Stroke Diesel 12 04-23-2016 07:44 AM
Need some help/advise - 00BlueOvalRanger 1999 to 2016 Super Duty 3 02-11-2014 02:01 PM
HEUI System (Injectors) - good write up bismic 6.0L Power Stroke Diesel 10 04-24-2007 04:08 PM
Tags
03, 04, 2003, 2004, 60, 60l, attitude, branch, early, edge, ford, forum, number, part, powerstroke, tube, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
