P2290 - Ford Truck Enthusiasts Forums
P2290
Old 05-06-2009, 07:38 PM
The Peanut's Avatar
The Peanut The Peanut is offline
The Peanut is starting off with a positive reputation.
P2290
Hi! I am wondering if anyone understands this code. P2290 - ICM Pressure Too Low. It popped up while on the highway, beautiful sunny day, crusing about 110kph (60mph) with a very light load (way less than my 9'9" camper). No driveabilty issues - just the silly light on the dash. The dealer reset it and I am to take it back if it comes up again...
2006 F350 DRW, 6.0 Diesel, Auto. 76,000km...
Old 05-06-2009, 07:46 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
I googled it and came up with this: experts should be by shortly.
The icp is injection control pressure its the sensor that measures the pressure of the high pressure oil system
The ipr is the injection control pressure regulator it controls the ammount of oil pressure the pump puts out.
These are both common problems with the 6.0 more so the icp on the early modle 6.0 because it was in the pump cover under the turbo and got hot and deformed the connector causing it to leak oil into the connector and causing all kinds of starting and performance problems. If you look in the passengers side valve cover and you do not see any sensor its an early modle if you do see a sensor its a late model.
P1260 and P2290 codes, truck still running fine hwybee22 6.0L Power Stroke Diesel 13 11-28-2016 09:23 PM
P2285 and P2290 codes, 2003 6.0 TXHillCountry 6.0L Power Stroke Diesel 11 11-30-2014 11:53 PM
P2290 Code and Hesitation Question Boats12 6.0L Power Stroke Diesel 6 04-19-2014 03:51 PM
P2290 trouble code Pittsburgh-05HD 6.0L Power Stroke Diesel 2 04-25-2006 09:32 PM
Can a clogged fuel filter cause a P2290 code? Brian460 6.0L Power Stroke Diesel 0 07-18-2005 02:42 AM
Tags
2004, 60, 60l, code, diesel, f250, f350, ford, icp, location, p2290, powerstroke, problems, psd, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
