98' Taurus (car) no start problem
I know its not a truck, but!!! it is a Ford
No pressure to the fuel rail and no power at the trunk relay, checked all the fuses and relays under the hood, all checked O'K. Any suggestions where else to look ?
Ran fine when I parked it, it sat several months and the battery died, replaced it and here I am.
I know somebody here will be able to help somehow, I posted the same on a Taurus forum but didn't get the response as I do here.
Thanks, Howard
Thanks, Howard
98' Taurus no start problem
I believe this inertia switch is the one in the trunk that I reset after changing the battery. However, upon checking further I found there was no power to either wire that came to the switch. Both the fuse and relay are in working order. Any idea where I might look from here?
Sorry for the delay in thanking you for the response, I changed e-mails and forgot to change it here.
Thanks for your help, Howard
helminc.com
1998 Taurus/Sable Electrical & Vacuum Troubleshooting Manual
Item number: FCS1212398 / $26.00
1998 Taurus/Sable Shop Manual
Item number: FCS1205598 / $55.00
This is just two examples of what Helm has for 1998 Taurus/Sable.
These are the original FACTORY manuals, the exact same ones all the FoMoCo dealers use. Helm has printed all of Ford's literature since the 1940's.
I would think the peeps on the Taurus forum would know about Helm. But it seems....obviously not.
98' Taurus no start...... started
Thanks guys, just an update.
Went to Ford service today and got to talk to a mechanic who was more than helpful. His thought was that a relay was sticking and gave me two to take home and try, well no luck there. Upon returning them to him he said he would come over after work and take a look, sure enough he showed up rechecked the fuses got in the car and started the dam thing right up.
"When I asked what he did he said that he turned the ignition on and off a couple times then hit the starter".....wala.
I told him I had done the same thing earlier when I installed his relays and didn't have the same skill as he.
He wouldn't take any $$ and said to keep his cell no. and if i needed him again, just call. He said that since it had set for several months that this wasn't unheard of.
Hows that for a good Samaritan ?
hgoody77
Tennessee Chapter
04-01-2009 10:36 PM
