What happens with too much is, first yoru fuel pump is working way to hard and wears out faster, second your engien usually runs way rich at idle and low speeds, and your fuel mileage sucks as well as most times you end up with 1 or more cylinders missing because you fouled the plugs.
Yeah this all took place after the stock fuel pump went bad and the only one I could find was one from NAPA.
