oem limited slip consensus
It all depends on what you use your truck for...If you are doing a lot of off roading, go with something more agressive. For everyday use, the OEM works ok if it is set up correctly and with the right amount of additive and you learn how to use your foot on the brake while spinning one tire to make the other one grab.
I have an F-250 that's six weeks old. It has the optional Limited Slip axle with 4.10 gears.
<O</O
The OEM limited slip is really weak. I found a place off-road where I pulled a rear tire off the ground flexing the suspension. I put the transfer case back in 2WD, left the transmission in Neutral, and attempted to rotate the lifted tire by hand. I found that the clutches in a basically new Traction-Loc could be overcome with relative ease, maybe ~50lb.ft. of torque to reach breakaway.
<O</O
An OEM limited slip would probably be OK if you never left the road, maybe if you're looking for better traction in inclement weather or at the boat tramp. Anything off-camber is going to be a letdown because you'll easily reach the breakaway torque of the clutches.
<O</O
The main thing I don't really like about the OEM limited slip is that it uses a plate-clutch design to transfer torque. By design, it's clutches are a wearable item. How long the clutches last depends on how wrong the differential fits your driving style: more one-tire-fires results in shorter clutch life and, therefore, even more one-tire-fires! At least the unit is rebuildable.
<O</O
In my opinion, if I were adding a limited slip differential, I'd go with something like a Detroit Tru-Trac. It doesn't use clutches, so it won't wear out like the OEM unit. Plus it has a higher torque biasing ratio. The Tru-Trac bias ratio won't diminish as the miles add up. But it doesn't have a way to preload the system. If a tire comes off the ground, it won't even transfer as much torque as the mild Traction Loc.
<O</O
If you do some internet searching, you might be able to determine the biasing ratios of these differentials. Don't quote me on this because it's been several years, but the biasing ratios for several popular traction aiding differentials were listed as follows: (most aggressive first)
<O</O
Auburn Pro Series --> Auburn High Performance Series --> Detroit Tru-Trac --> Traction Loc --> Open Differential.
<O</O
This is with a new differential. The Auburns start out very tight but use clutches (although a little differently). Their biasing ratio goes down with use. The Tru-Trac stays consistent.
<O</O
I know this is a super-long reply. But I like to make an informed decision.
<O</O
<O</O
<O</O
<O</O
<O</O
<O</O
<O</O
<O</O
Note that there's a "reason" for the Trac-Loc for being so "loose".
Just like the oil pressure gauge, too many people didn't understand how they worked, and thus complained about the performance -- too much noise/chatter, etc...
Too much friction-modifier, and wavy clutch plates that are assembled with the waves "matched" instead of opposed.
Word around "these parts" is that a competent Ford tech can rebuild them "correctly" and thus result in "proper" function.
-blaine
-blaine
If you are going to add a limited-slip, do NOT use the Ford Traction-Lok. If you already have one, try reducing the amount of friction modifier in the gear lube.
My stock Traction-Lok works OK when I have only 4oz of friction modifier in it, but the book says 8oz. It also chatters a bit, but that's OK.
Last time I got new tires, I topped up to 8oz friction-modifier, I wanted to save my tires
OEM Traction-Locs are ok when properly set up. Most SD's I've owned they were too loose. Only 50 lb/ft on the torque wrench would overwhelm them. The f150's I've owned were mostly good, way tighter than the SD's. And I do get some chatter on the F150's when cornering. But it's nice to see gravel flying from both rear wheels when you hit the throttle.
