Power Inverter Install (long w/ lots of pics) - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 01-08-2013, 06:02 PM
infinite-foamies's Avatar
infinite-foamies infinite-foamies is offline
infinite-foamies is starting off with a positive reputation.
I have a huge wiring job im about to embark on. I cant fit everything under the set or rather i think i would have a cooling issue... so i am lowering the floor pans in several spots.
here is what i plan to install:
2000W inverter
converter
UPS(uninteruptible power supply)
mobile ham radio with built in 150w amp(remote head unit)
house battery(s) (probably going with one for now)
outlets throughout and passthrough for my slide in camper
20a shore power inlet
rv style circuit breakers
I have everything except for the 2/0 cable for my inverter, some of the breakers and few small items like conduit and strain reliefs.
what do you guys think of lowering the floor pan instead of going under the seat? think i could get away with going under the seat?
  #32
Old 01-09-2013, 05:21 AM
lartross's Avatar
lartross lartross is offline
lartross is gaining momentum as a positive member of FTE.
I did a similar thing, but I used a glow plug relay controlled by a sw on my dash and an inline 100a fuse. Ran my wires to a pos and neg standoff I mounted on the frame of my back seat so I can run my 400w full sine wave inverter or my 1100w modified sine wave inverter...or both if I'm careful. My goal was power for my laptop or power for my wifes oxygen generator or power for whatever. [she has emphasima].
  #33
Old 01-09-2013, 08:21 AM
srteach srteach is offline
srteach is gaining momentum as a positive member of FTE.srteach is gaining momentum as a positive member of FTE.
2000W inverter
converter
I wouldn't think you need to lower the floor pan. Most of that stuff can fit under the rear seat. If you need more cooling space, you can use the under front seat area or under the center front seat area to spread items out.
I raised the rear seat by adding square tubing between the floor brackets and seat rail. There is still enough rear headroom for 3" above the head of my 6'5" boys. That would add enough space under the seat for what you want to put under there.
  #34
Old 01-09-2013, 10:24 AM
i have a centurion truck so the front bench was replaced with captains seats. no room underneath.
although i hadnt though about raising the rear seat. that is much simpler and undo-able. thank you. maybe i should cut the rug out though so it is a more capable heat conductor and air convection is also more possible underneath the items?
  #35
Old 01-09-2013, 11:45 AM
My truck has the 40/20/40 individual front seats. I could place things under the front seats, though I don't.
Cutting the carpet is NOT un-doable. I would never cut the carpet out. Truck value will be instantly lower, noise in the cab will increase, and rear of the cab heating will be more difficult. You won't get the heat transfer that you need anyway unless you go to bare metal and use a heat transfer compound between the item and the body.
Hanging items under the seat rail would make cutting the carpet a moot point. You could build a hanging frame if the devices don't allow for direct hanging or different orientation (O2 bottles for example). It would allow airflow above, on both sides (with spacing), and below the item, and let the fans built into devices work properly. Wires can be routed through the body holes, and protected outside the body or routed down the wire channel at the bottom of the door. Cleaning the inevitable dust and crumbs would be easier if devices are not attached to the floor.
Only you can determine the amount of space you need. Do it how you want and need, but those are my thoughts.
  #36
Old 01-09-2013, 01:32 PM
i dont intend to ever get rid of the truck but that is a good point. I am most likely running the wires under the truck through conduit (all wires except 2/0) and running the 2/0 straight with some form of abrasion prevention. thanks again for your two cents! I will make sure to take pictures.
Build Thread: 1993 f150 restoration project npd23 1987 - 1996 F150 & Larger F-Series Trucks 17 01-15-2013 08:25 PM
2011 NSRA Show in Kalamazoo Michigan - Lots of photos teardropty 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 09-20-2011 12:00 PM
Bored. So I took some pics. hammerhead90 1987 - 1996 F150 & Larger F-Series Trucks 32 08-28-2011 12:40 AM
Pics of my 1977 SuperCab 77 Supercab 1973 - 1979 F-100 & Larger F-Series Trucks 12 08-10-2011 08:46 PM
Now that is some SERIOUS flex! With some mud in the mix.. PICS... YellowSled Excursion - King of SUVs 15 10-03-2010 12:20 PM
Tags
120, 2004, 2006, f150, f250, f350, ford, install, installing, inverter, outlet, power, truck, volt, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
