1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Mobil 1, Royal Purple, or Motorcraft?
Old 05-05-2009, 08:31 PM
azfordf100man's Avatar
azfordf100man
azfordf100man is offline
Use Amsoil, they make a great gear lube.
Old 05-06-2009, 10:40 AM
Fat Diesel's Avatar
Fat Diesel
Fat Diesel is online now
A coupla tips from someone who's done this job a few times now:
1- Leave room for the friction modifier when you put in the gear oil. If you pour gear oil up to the overflow, you'll have a hell of a time pouring in some f.m.
2- Go easy on the modifier. You can add it in steps. Once you pour in the new gear oil, get it worked into the clutches. Go do figure eights somewhere. If you start chattering, especially turning left from a stop, add 4 oz and do some more figure eights. If you still get chattering, add 4 oz more and repeat!
I've used Red Line and Royal Purple in mine and needed 8 oz both times. Some people don't need it at all, that's the point of determining where you are and going from there.
Old 05-06-2009, 11:19 AM
busdriver47's Avatar
busdriver47
busdriver47 is offline
I just changed mine i use redline.
Old 05-06-2009, 12:10 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I used Mobil 1 and started with 2 oz of friction modifier. The limited-slip chattered, so I had to add another 2oz and it reduced the chatter to a reasonable amount while allowing my LS to actually work very well.
When I got my Goodyear Silent Armors, I added another 4oz because I wanted to save the tires
Limited-slip still works OK, but not as well as with only 4 oz total.
Anyway, long-story-short, when I used plain-jane Mobil 1 synthetic 75w140, it NEEDED friction-modifier for my limited-slip
Old 05-06-2009, 12:13 PM
UGA33's Avatar
UGA33
UGA33 is offline
Dont have time this week to do it and no one had Mobil 1 around town so i just went to Ford to get a qt of the 75w140 and some friction mod. to top it off. I am going to fix the pinion weep and change the fluid all in one shot when i get a chance in a couple weeks!
Old 05-06-2009, 12:34 PM
cartmanea's Avatar
cartmanea
cartmanea is offline
How are you going about fixing the pinion weep? Mine's been weeping ever since I changed gears, never has dripped so I'm not worried about it. I cleaned the pinion sealing surface up really well and used a new seal, but it weeps... Are you planning on using a speedy sleeve or something else?
Old 05-06-2009, 12:48 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
If the seal is weeping, CHECK THE BREATHER.
Old 05-06-2009, 01:05 PM
bryyce62's Avatar
bryyce62
bryyce62 is offline
Hey Art,
I didn't have to add any FM with M1. Is that an indication that my LS is wearing out?
Old 05-06-2009, 01:16 PM
cartmanea's Avatar
cartmanea
First thing I did, but good advice for UGA33
Old 05-06-2009, 03:21 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Originally Posted by bryyce62
Hey Art,
Could be... Not sure if there's a Mobil 1 out there WITH friction modifier, or if for some reason the stuff I used was different. I'll see if I can find the bottle of leftovers.
Old 05-06-2009, 03:59 PM
bryyce62's Avatar
bryyce62
bryyce62 is offline
I was under the impression that Mobil 1 has friction modifier. My unit performs good, no chatter, but I'll admit I haven't really tested the slip since the fluid change.
Old 05-06-2009, 04:58 PM
riggz's Avatar
riggz
riggz is offline
I saw some mobile 1 bottles that said "LS" on the side and said it was for limited slip differentials, so maybe it has some in there. I'd rather be able to control the amount to confirm that it is correct.
  #28
Old 05-06-2009, 05:24 PM
UGA33's Avatar
UGA33
UGA33 is offline
I will do that right now!
  #29
Old 05-06-2009, 09:51 PM
EXv10's Avatar
EXv10
EXv10 is offline
Mobile 1 makes two types. 1 is LS and 1 isn't. LS has the mods in it.
snickers104
06-06-2017 07:42 AM
Boomer Sooner
EcoBoost (all engine sizes)
06-01-2017 01:19 PM
jschira
2017+ Super Duty
76
03-10-2017 06:43 PM
EddieEX10
12-19-2016 09:33 PM
dalfollo
1997-2006 Expedition & Navigator
03-13-2004 03:43 PM
Quick Reply: Mobil 1, Royal Purple, or Motorcraft?
