y pipe for 5.4 super duty - Ford Truck Enthusiasts Forums
Old 05-05-2009, 12:00 AM
303soul 303soul is offline
303soul is starting off with a positive reputation.
what are the actual power gains after replacing/modifying the y pipe in a 2003 super duty, a certain website claims 35 hp on the dyno which seems a bit far-fetched to me, but besides a throatier sound are performance gains significant? My exhaust guy said he could do the modification for two hundred dollars; is it a worthwhile investment?
Old 05-05-2009, 12:54 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
The "somebody website" uses the same formula for figuring the K&N sticker and CAI add's 35 hp to the engine too! (grin).
Check out muffle flow test on the net- you might be alitlle surprised at the results of different mufflers. Yes, the y pipe could be better, does it help, sure, but considering the biggest flow restrictor is just down from there (the cat), how much good are you really doing? ya know what i mean.
Old 05-05-2009, 03:23 PM
dkf's Avatar
dkf dkf is online now
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Look on page 4 in this thread http://www.ford-trucks.com/forums/82...-2v-dynod.html
Keep in mind the above thread is the 99' y-pipe on a V10. The 00'-04' y-pipe is a lot worse than the 99' y-pipe.
I would go with the SPD replacement y-pipe section. SPD Performance Just cut out the bad section and weld in the new SPD piece. You will then have an all mandrel bent y-pipe thats fairly equal length. You should notice a power increase. As for the 33hp 35tq claims not on the 5.4l maybe on the 6.8l at a given point in the rpm range.
If you want more power a good tuner can help a lot even on 87 octane. (See thread)
Old 05-05-2009, 05:34 PM
cmullins cmullins is offline
cmullins is starting off with a positive reputation.
I put the SPD Ypipe and a flowmaster FM70 on my V10 and love it. Most noticable is the tip-in performance. Muffler guy charged me $110 to install both. IMHO - good mod and worth the money. Definately read the 5star thread. I bought the tuner and it is without a doubt the best money I have spent.
V-10 Y pipe Giterduun 1999 to 2016 Super Duty 13 08-08-2014 03:50 PM
1994 F-450 (F Super Duty) Y-Pipe Alegra0272 1987 - 1996 F150 & Larger F-Series Trucks 5 12-30-2013 12:27 PM
5.4 Y pipe masond Exhaust Systems 2 12-17-2011 08:07 PM
y pipe on 99 worth the effort and cost? kengarchow Modular V10 (6.8l) 33 02-19-2009 01:17 PM
2000 V10 Y-Pipe ascheperle Modular V10 (6.8l) 3 12-23-2005 08:09 AM
Tags
2003, 2007, 54, duty, flowmaster, ford, gains, hp, increase, pipe, resrictor, spd, super, superduty, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
