Need help to find49 Door latches
I'm going to try and add two pictures of the door mechanism in my F47 Panel (Canadian #, US F1). The cam that is operated by the outside door handle has worn away and will not retract the latch. I can probably weld some metal on and the re grind the cam but if I can get a replacement it would be the best solution. I might as well get the right side mechanism as well since it is probably worn.
[/IMG]
[/IMG]
The top picture shown the frame that attaches inside the door and the handle fits into the square hole. The bottom pictureshows the cam and the wear on it.
Any suggestions would be appreciated.
[/IMG]
[/IMG]
Oh I just have a tear in my eye - all my FTE youngsters are growing up!
Tee hee.
Yeah Wood, but ya needed to give him the link to that thread.
I think this might be it:
https://www.ford-trucks.com/forums/7...r-handles.html
It's a piece o' cake!
If you need any advice "Wood" will be glad to help out
Tee hee.
Thanks Julie
Tee hee.
Tee hee.
